Quick Rigid Industries DOT Dually Output Shots
Some quick output shots of the new DOT Approved Fogs with OEM Projectors from Total Automotive Performance team member @goneFXcrazy
Gives the truck a much wider light coverage area while still providing a DOT Compliant light cutoff. The range is also impressive, unlike standard reflector housings, the beam carries on nearly as far as the headlights depending on how you aim them. In these pictures they are aimed at the same level as the headlights but they should really be aimed a few inches lower for the real world.
As always PM/call/email us for our best deal but you'll have to act fast, these are FLYING off the shelf! :thumbsup:
Low beams only
Low beams and DOT Fogs
All pictures taken at ~30-40ft from wall.
