Toyota 4Runner Forum
Register *new* Garage Photo Albums FAQ Members List Social Groups Calendar Mark Forums Read Sponsors
Go Back   Toyota 4Runner Forum > Toyota 4Runner Forum > Lexus GX470/460
LinkBack Thread Tools Rate Thread Display Modes
Old 12-24-2010, 01:08 PM
  #1 (permalink)
Registered User
03_4x4Runner is an unknown quantity at this point
Premium gas on GX 460
I am looking into buying a GX 460 soon. Have any of you been running regular gas. I have been running regular gas on my 03 V8 4runner since new with no problems but not sure about the new 4.6. I really just want to run regular.
03 4Runner SR5, V8, 4x4, Daystar lift, 265/70/17 BFG all terrains
http://home.graffiti.net/Jeeper_Dan:.../AZ4runner.jpg
03_4x4Runner is offline
Old 12-24-2010, 01:20 PM
  #2 (permalink)
Koz
Bad Ass Member
Koz's Avatar
Koz is on a distinguished road
The GX460 has been designed and tuned to require premium fuel.
Koz
Koz is offline
Old 02-14-2012, 12:37 AM
  #3 (permalink)
Registered User
seahaul is on a distinguished road
Koz
The 4.6 is in other vehicles that don't require premium, what would Lexus do that makes it require premium. I asked a Lexus salesperson and he didn't really have an answer (as expected) when i pointed out it was in all kinds of Toyotas.
seahaul is offline
Old 02-15-2012, 03:42 PM
  #4 (permalink)
Registered User
08GX470Driver is on a distinguished road
Despite the engines being very similar, you can see there are some tell-tale signs that they are very different.
If you'll look here at the 2012 gx460 specs http://pressroom.toyota.com/releases...+info.download
and here at the 2012 tundra specs http://pressroom.toyota.com/releases...tures.download
you'll see that they do in fact both have the "same" 4.6 liters of engine. The differences start to pile up immediately though. For instance, in the tundra the bore and stoke is: 3.70 x 3.30 in. In the GX460, it is 3.70 in. x 3.27 in.
GX460 hp numbers: Horsepower (SAE) 301 hp @ 5,500 rpm
Torque 329 lb.-ft. @ 3,500 rpm
Tundra hp numbers: Horsepower 310 hp @ 5,600 rpm,
Torque 327 lb-ft @ 3,400 rpm
Also, we see that the tundra engine is Direct injection alone, wheras the GX460 version is MFI.
So despite both engine being of the same designation, the gx460 requires 91 unleaded because it was designed for it obviously. It's quite possible that the gx460 ecu is programmed more aggressively to take advantage of the higher octane and the tundra is not.
Take your pick of reasons that they differ, the point is if the manufacturer recommends premium it is because the engine was designed to and runs "better" on it than on regular, whereas that might be the exact opposite for the tundra.
I was in a similar situation before we purchased our GX470 coming from a 5.3l envoy. All in all we spend about 4-6 dollars more a tank and get the same or better mileage so I really wouldnt be that concerned about just buying the premium. Also, it probably wouldnt help to put regular in it anyway, because the ecu will probably detune the the engine accordingly to knock it may sense. You wouldnt know that its happened until after you got worse mileage....
08GX470Driver is offline
Old 02-16-2012, 09:58 PM
  #5 (permalink)
Registered User
tick2791 is on a distinguished road
I have owned a gx470 for 5 years and have run both 87 and 93 at diff times. The 93 gets better mileage by 2 miles to the gallon (20mpg compared to 18 with 87 octane- highway mileage.) I have never heard it ping or knock with the lower octane. The shop that works on my truck says it will run fine on 87 or 93. The owners manual says nothing less than 87 but suggests 91 for better performance
tick2791 is offline
Old 02-17-2012, 09:36 AM
  #6 (permalink)
Koz
Bad Ass Member
Koz's Avatar
The 4.7 was designed to run on regular. Unless you towed close to the maximum tow rating there was/is no benefit to running premium fuel. The ONLY purpose for running higher octane fuel is to prevent engine knock/ping. There is no difference in the amount of energy between regular and premium fuel. The best fuel to use is the lowest octane fuel that will not cause knock (usually OEM recommended octane). Using higher octane (on a stock engine) then what the OEM recommends is a waste of money!
When an older engine has carbon build-up (raising the compression ratio) that can not be removed (or you do not want to spend the money to clean), you can use a higher octane to prevent knock.
Koz
Koz is offline
Old 02-17-2012, 03:58 PM
  #7 (permalink)
Koz
Bad Ass Member
Koz's Avatar
BTW - The reason the GX requires premium fuel is because the GX's 1UR-FR 4.6 engine is tuned (valve timing) to be smoother and quieter.
Koz
Koz is offline
Old 02-17-2012, 04:05 PM
  #8 (permalink)
JB.
Registered User
JB.'s Avatar
JB. is on a distinguished road
Toyota recommends 87 or higher or premium for "improved vehicle performance" in the 4th gen.
2005 Limited V8 XREAS
Galactic Grey
Revo 2 LT265/70/17 E
Replaced BFG A/T KO Load C
Hanna sliders
JB. is offline
Old 02-18-2012, 02:29 PM
  #9 (permalink)
Koz
Bad Ass Member
Koz's Avatar
I tested the 4.7 V8 with regular and premium and there was NO difference in milage (even when towing). What is more important then octane is how well your fuel keeps your engine clean.
Top Tier Gasoline
Koz
Koz is offline
Old 02-18-2012, 03:59 PM
  #10 (permalink)
JB.
Registered User
JB.'s Avatar
Who knows, but use of premium does qualify as an OEM recommendation.
Galactic Grey
Hanna sliders
JB. is offline
Old 03-02-2012, 12:44 PM
  #11 (permalink)
Koz
Bad Ass Member
Koz's Avatar
Originally Posted by xiyour View Post
FR 4.6 engine is tuned to be smoother and quieter.
I'd rather have the 9hp and run on regular!
Koz
Koz is offline
Trackbacks are On
Pingbacks are On
Refbacks are On
Premium vs. Regular Fuel Thai Maintenance 94 01-08-2012 05:48 PM
Premium Gas (possibly dirty) - Check Engine and other lights Blubble Problems & Warranty Issues 0 09-11-2008 05:33 PM
Premium Gas: Better Mileage & More Accurate Computer? TeryT 4th Gen T4Rs 19 09-26-2005 09:56 PM
Loose gas caps and "check engine" lights Thai Problems & Warranty Issues 0 06-09-2003 11:23 AM
Premium vs. Regular Fuel...the Final word? Thai Maintenance 3 04-10-2003 10:01 PM
» Current Poll
Who should win T4ROTM May 2012
93Toy - 29.55%
13 Votes
SV_Dude - 22.73%
10 Votes
Slacker - 34.09%
15 Votes
Drz400smoto - 13.64%
6 Votes
Total Votes: 44
You may not vote on this poll.
» Facebook Page
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» T4R Sponsors
T4R Gauge Swaps Key Insurance
Metal Tech 4x4
4xInnovations
Toyota TRD Parts
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Optimization by vBSEO 3.6.0
