Cleaning Your Car
Iron-X for rust specs on white paint? ( and where to buy )
I was alarmed to spot a few rust specs on the tailgate of my 7 month old white ( blizzard pearl ) T4R this morning. Did some online research and it looks like Iron-X might be a good product to clean these up.
Have others here had good results with Iron-X, and any suggestions on where to buy in the Vancouver,BC or Bellingham,WA areas?
Thanks!
Hello all:
I have wondered how people are able to apply protectant (I usually use 303) to the exterior rubber molding and trim around the windows and doors without leaving a mess on the car itself? The protectant usually ends up on the windows. Then, if I clean the windows it seems like I clear off more of the protectant than I like.......
Any advice on techniques or sequence here?
Thanks, Steve.
I always spray 303 onto a mf rag or sponge first before applying onto whatever surface you're trying to protect.
If you really want to make sure you don't get the protectant on a painted surface, use painters tape around the area you're trying to protect.
i detailed cars for a while. pretty good. but also id like to warn others. that if you go to a dealership and get some kind og 5 or 800 dollar wax, its a scam, its snake oil. you can buy the stuff pretty cheap, we got a whole case for 100$ and that was good for well over 100 cars. i called it scotch guard cause thats what it really is, its like 20$. good for interiors.
dealership scams
i detailed cars for a while. pretty good. but also id like to warn others. that if you go to a dealership and get some kind of 5 or 800 dollar wax, its a scam, its snake oil. you can buy the stuff pretty cheap, we got a whole case for 100$ and that was good for well over 100 cars. i called it scotch guard cause thats what it really is, its like 20$. good for interiors.
Also if you guys want better results buy the small hand buffer they sell at autozone or walmart in the detailing section ($20), its a great beginner buffer. It not powerful enough to damage your paint if you make a mistake and really brings out close to professional results after putting in some time using polish and wax! But make sure that the surface is clean!! You dont want to use a buffer on dirty paint! :yo:
My outlined white letters were pretty neglected and I was on the hunt for an easy and inexpensive why to brighten them up. After searching online I found one suggestion to use 320 grit sandpaper.
I used small pieces of sandpaper and gently sanded on the letters. I was very tentative at first... I couldn't believe how nice and white they came out.
scratches on interior plastic door handles
When detailing the interior of my 2013 4Runner, is there anything I can do about these scratches? I am a single mom and not very handy and am also on a budget. Any ideas appreciated.
What does everyone think of the car washes that contain wax? It seems to work, water beads up on my vehicle after washing with meguiars ultimate car wash.I gave up on waxing my vehicles. With all the construction here in Texas I cant keep my paint looking nice and it bums me out. I get a new rock chip weekly. Has anyone in the DFW area experienced this as well?
I use meguiars ultimate car wash and its the best ive tried. I also use meguiars ultamate wax and it wipes on and off very nice after letting sit for 7 mins, so far it is the best ive used and lasts up 2-3 months. I think the car washes with meguiars ulmate wash in between waxing also helps it beeding water away and i think stays cleaner longer. I also got sick of water spots after washing so i tried out sasquatch drying towels by i think chemical guys and i love them, very soft and absords very good, got 3 towels so after the first 2 get to wet to wipe dry after wringing out i use the 3rd one for final dry and finally no more water spots.
I would never use a car wash especially with that type of wax. You can easily hand wash your vehicle and apply a coat of wax. You should always have a coat of wax to protect your clear coat and paint. I would do a good hand wash, claybar then apply a coat of your favorite wax. I prefer Griots Garage, Collinite or Meguiars Ultimate. They are all pretty decently priced and your vehicle will look great plus you get good protection against the elements.
I've never used that type of car soap but I've seen many that get positive reviews on detailing forums & online forums.
When I have the time, I use a sealant (Klasse twins) followed by wax (P21s). When I'm in a hurry I just use the sealant. The combo or sealant alone seems to last several months, and my 4Runner is outside a lot of the time in all kinds of weather. Any sacrificial layer has to be better than none :) YMMV.
Car washing
I love washing my car properly. I am also OCD and hate having any blemish on my cars. Preventing damage to the paint through washing is very important to me. I use two bucket technique for washing the body but have a seperate bucket for the wheels. My process is as follows.
Prepare buckets
1 soap 1 water 1 wheel (your choice of soap, dilutions and type can vary for type of wash, use deep pile wash mit, I have three 2 for body 1 for lower portions that gather the most road debris)
Prepare surface of car
Rinse car thoroughly, taking time on each section at a medium pressure setting. Next snow foam entire car. While foam is soaking/taking dirt away, clean each tire with brush, 2 back tires first then front two. Rinse car and wheels off.
Wash car
Using soft wash mit and 2 bucket method (along with grit guards) start at roof wash half get new mit and do the other half, rinsing out the used mit in the rinse bucket thoroughly then into soap bucket then onto car. Move to hood then glass then sides of car (top to bottom used 3 mit for rocker and lower portion of car) Lastly the boot of the car. I am constantly moving the mit back to the rinse bucket trying to get any dirt and grit off the mitt, even one tiny particle can and will introduce swirls/belmishes. It is absolutely key to avoid this, hence a lot preparation time with initial rinse/snow foam. I do all of this in a car wash bay, I don't use any of there provided soap or spray except for the snow foam gun. After washing the car with a mit I rinse off and move to
Drying
I have tons of microfiber towels, different piles and sizes. My favorite are from chemical guys and are the oversize MF towels deep pile. I have 6 of them that I can cover the the entire top and hood with, I lay on top and pull off, no rubbing just pat dry. I spray the car with a quick detail/wax/sealant before drying the surface. Towels must be thoroughly cleaned prior to use. I again dry top to bottom with the 6 towels. After which I am about done, I use my quick detail and new smaller MF towels for any touch up. If the towel is too wet or dirty I stop using it.
I follow this by a wax or clay and wax every 3 months. I don't buy the most expensive products just products that work and are trusted. I don't spend more than an hour washing my car unless clay/wax or polish is needed. I am OCD but this keeps my car paint looking better than most and if I ever sell my car I am rewarded for it. I used this process for the life of my previous car (black paint) and had very very little to no swirling or blemish from washing. I will keep this process tho for my white car which I can't see dust accumulate hours after washing like on black (but i know is there), hence why I would never touch the car after the washing/drying process is complete. This is just MY process I wanted to type it out somewhere so I can reference it. Other tips: never use auto car wash, even the touch-less ones use super high pressure that can mar the paint even if it is completely clean add dirt on the surface and that high pressure just becomes higher grit sand paper. Hope this helps someone.:)
Great tips! I'm getting ready to sell by '97 4runner, so this is the perfect thread. Thanks!
erinobr2000
