Old 08-19-2009, 08:15 PM #1
kevincook kevincook is offline
kevincook is on a distinguished road
How to replace front wheel bearing.
My wife's 04 4runner needs a new right front wheel bearing. I just picked up the part while I am doing a brake job. Can someone tell me how to get the old front wheel bearing off?
I'm guessing I need to disconnect the front axle shaft someplace. Is this correct? I don't want to start tearing things apart that don't need to come apart.
Thanks,
Kevin
kevincook is offline   Reply With QuoteReply With Quote
Old 08-19-2009, 09:38 PM #2
I have the rotor and caliper off and I have removed the hub nut. I can see where the bearing module bolts on but I need to get the hub off first. Will the hub pull off or do I need to disconnect the axle shaft someplace first?
Thanks,
Kevin
Old 08-20-2009, 09:13 AM #3
03L4RUNNER's Avatar
03L4RUNNER 03L4RUNNER is offline
03L4RUNNER is on a distinguished road
03L4RUNNER's Avatar
Did this my self on my 03 about a month ago, , , my advice is dont do it unless you have some experience and feel confident in spacing the bearing/ seating it properly, you can search my name on 120 and there is more info on it there
2003 Limited 4WD V6
OME W/Toytec Topout, LR UCA's, 255/80R17 BFG KM2's, Defiant LB, Viair OBA W/Mack Horn, Tundra Split Spokes, Wet Okoles, 5% Tint, K&N CAI, and various other additions
03L4RUNNER is offline   Reply With QuoteReply With Quote
Old 08-20-2009, 09:14 AM #4
03L4RUNNER's Avatar
03L4RUNNER's Avatar
Thanks,
Kevin
You do not disconnect the front axel in anyway
2003 Limited 4WD V6
Old 08-20-2009, 09:20 AM #5
Does the 03 have press in bearings or a bearing module like the 04?
How did you get the hub off in order to unbolt the bearing module?
Can you explain what you mean by spacing the bearing? I've never had to do that on a wheel bearing before.
Thanks,
Kevin
Old 08-20-2009, 10:23 AM #6
03L4RUNNER's Avatar
03L4RUNNER's Avatar
Thanks,
Kevin
Spacing meaning you cant just press a two piece bearing in, it has to have the proper tolerances or you will just burn through another on in no time
2003 Limited 4WD V6
Old 08-20-2009, 01:32 PM #7
Thanks,
Did you remove the front steering knuckle also?
Kevi
Old 08-20-2009, 01:48 PM #8
03L4RUNNER's Avatar
03L4RUNNER's Avatar
No i did not, you only have to remove the 4 bolts holding the bearing housing on, no further than that, but dont forget to put your brake dust sheild back on during the install(I forgot to put mine back on. . . .But at least my brakes stay cooler now lol)
2003 Limited 4WD V6
Old 08-20-2009, 01:52 PM #9
I loosened the four bolts but couldn't completely remove them because they hit the hub. The bearing seems stuck to the steering knuckle. How did you separate them?
Thanks,
Kevin
Old 08-20-2009, 02:04 PM #10
03L4RUNNER's Avatar
03L4RUNNER's Avatar
with a three jaw bearing puller, and put the bolt on the bearing puller on the threaded axel shaft, but be easy with it and then you can loosen the bolts the rest of the way
2003 Limited 4WD V6
Old 08-20-2009, 02:05 PM #11
03L4RUNNER's Avatar
03L4RUNNER's Avatar
Looks like this, ,, i really wish i had my camera with me at work to show you
How to replace front wheel bearing.-aaronngu77@122-jpg
2003 Limited 4WD V6
Old 08-20-2009, 02:15 PM #12
I'll have to try again. I was trying that but it is pulling the steering knuckle/bearing and hub off the axle.
Does the bearing go into the steering knuckle at all?
Kevin
Old 08-20-2009, 02:19 PM #13
03L4RUNNER's Avatar
03L4RUNNER's Avatar
Steering Knuckle? this has nothing to do with that
2003 Limited 4WD V6
Old 08-20-2009, 02:58 PM #14
The steering knuckle is the cast piece that all of these parts are attached to.
Kevin
Old 08-20-2009, 05:28 PM #15
mjos's Avatar
mjos mjos is offline
mjos is on a distinguished road
mjos's Avatar
2 other ways to do it for the tool challenged:
Turn the axle nut around and thread it back on to where it is almost even with the end of the shaft. Then take a block of hardwood and a hammer and tap the wood squarely on the nut. It should come off after a few medium swings.
Or, take the axle nut off, put your wheel/tire back on and tighten the lug nuts just enough to hold. Then use the wheel as a slide hammer by pulling it away from the hub. This usually pulls the 4 bolt hub assy away from the knuckle. Jeep guys with the D30 front ends and unit bearing use this method all the time. On the Yota you have to be careful though so that you don't pull the CV axle out of the differential. I prefer method # 1, just don't mess up the threads by hitting it too hard.
2005 4-Runner, Sport 4x4, V8, Toytech Ultimate 3" lift, Trail Gear Sliders, 285/70-17 BigO AT, Spidertrax Spacers
mjos is offline   Reply With QuoteReply With Quote
