New Tires...
T4RVA
As you all may read from my last thread, I had Cornfed 3/2 lift and Spidertrax 1.25 wheel spacer installed...
This morning, I'm getting 275/70/18 Good Year Wrangler Silent Armor tires put on the T4R. I can't wait to see the new boots! I'll post new pics.
Bad news, the 275/70/18 caused rubbing... I had to remove wheel spacers to minimize the rubbing.
I liked having the wheel spacers and wider stance... Any suggestions to what I can to do re-install the wheel spacers and have no rubbing?
Thanks in advance.
Thanks in advance.
Or, should I just mount the wheel spacers in the rear?
Here is my T4R with Cornfed 3/2 spacer lift and 275/70/18 Goodyear Wrangler Silent Armors...
Thanks in advance.
Check out his web site.
Unscrew the front liner and pull it forward. I have the same size tires and that what I had to do. I will later drill some new holes onto the liner to hold it into place. I'm using duc tape to hold the liner in place for the time being.
i followed the instructions from JA's site for trimming. I'm still rubbing a little, but only at full lock.
That looks like fairview park...right?
I used to live in NOVA for 4 years...thinking about moving back.
Actually, the pic was taken in Tyson's Corner. Let me know when you are planning to move back and need to purchase/rent a home. I'm a part time real estate agent.
Thanks.
t4rva
I am looking at doing the exact same lift, Cornfed 3/2 with spider trax and 275/65/18's I see 2 different tire sizes here though, 275/65's and 275/70's which ones are on it right now and what were the rubbing issues and solutions?
