Any one run 245-75-17 ???
8086bruce
Just seeing if anyone has run 245-75-17 tires? I want a little taller than stock but maybe not as much as 265-70's This size seems to be rite in the middle.
lot of people here run 255/75/17 I know that. It is 32.3" tire in my application so its slightly taller than 265/70/17. 255 still fits fine without any rubbing so I don't know why you would want to go with 245 instead
The O.D. of the two is very similar, in the 31.5(6) arena. If you truly want a half-way tire look at the 255/70.
:iagree: with paraordnance though... No need for a 31" with your rig, closer to a 32 will work fine. My 1st choice would be the 255/75.
