#31 (permalink) |
Registered User
It turns out that soldering the diode DID NOT do further damage to my relay -- I simply made a mental mistake when testing the relay on the bench, post soldering.
More importantly, with the case removed, I can confirm that the diode isn't shunting the kickback (i.e. I can see an arc every time the relay contacts open). Apparently I made a 2nd mental mistake since the diode as installed can't possibly redirect the EMF since it will always be reverse biased. The bypass needs to go to ground. There isn't a ground rail available to this relay, so the bypass diode will have to be installed elsewhere in the circuit. I'll post an updated solution when I have it -- sorry for any confusion.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix Last edited by rando; 05-09-2007 at 09:28 PM. |
| Sponsored Ad | # |
Advertisement
#32 (permalink) | |
Registered User
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix |
#33 (permalink) | |
Registered User
Thanks for the update Rando. I was wondering about the way you wired the diode but wasn't quite sure myself. Now we know.
So I went to poke around under the hood and look in the fuse box. Turns out I don't have to worry about this because the following applies... Quote:
Good luck guys.
__________________ '04 SR5 V6 4x4 Galactic Grey Mica. Delivered 03/17/2004. Link to my mod list in posts 7, 8 & 9 of this thread: http://www.toyota-4runner.org/general-discussions/21354-diy-mods-post-write-ups-here.html ____________ [__/[_[_\____\,_ L---L-L-L--0=*=0 `(o)_---(o)_--)_)`......... ``````````````````````` The battle begins at the end of your driveway... Game On! "Car!" |
#34 (permalink) |
Registered User
SOLUTION: MGCLT Relay Mod
The narrative in the following posts describes how I mod'd the magnetic clutch / magnetic clutch sensor circuit to prevent premature failure of the MGCLT relay. In my case, the relay had already failed before I learned of the problem. To test this modification I further destroyed my relay by removing it from its casing. Had the modification been in place earlier, I believe relay failure (and a costly $50+ replacement) could have been avoided.
This modifcation done correctly or not may start your truck on fire, or otherwise cause damage or injury to people, property, or the universe. It worked for me, as described, but I cannot guarantee that it is safe or that it will work for you. By attempting this modification, you agree to proceed at your own risk and accept full liability for your actions and their consequences. The information provided here is for informational purposes only. I do not endorse this modication nor recommend that ANYONE actually perform what is described.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix Last edited by rando; 05-09-2007 at 10:53 PM. |
#35 (permalink) |
Registered User
These are the locations to connect the diode. The diode is hidden underneath the heat shrink. The red sticker indicates the diode anode.
Anode goes to GND - Pin #4 (center pin) of the Heater relay Cathode (striped side of diode) goes to the load - Pin #3 of MG CLT relay
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix Last edited by rando; 05-11-2007 at 05:44 AM. |
#36 (permalink) |
Registered User
Here's what it looks like with the relays installed. Hopefully your MG CLT relay doesn't look like mine!
If you're just reading these last two posts, I've confirmed that this eliminates the arcing inside of the relay. If you have the old style relay and it hasn't failed yet (and you're out of warranty), you can save yourself $50+ and install the bypass for < $1.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix Last edited by rando; 05-09-2007 at 10:36 PM. |
#37 (permalink) |
Registered User
The diode goes across the coil of the relay which one side is ground, so if that pictured diode is across the coil and positioned correctly; then it should work fine to prevent a reverse huge voltage spike when the relay de-energizes.
2003 4x4 Sport 4runner V8, Scion HU w 4 upgraded speakers, Hella horns, MapLight Mod, de-badged 85 k + miles 1994 Jeep GC with 202,500 miles 1990 Corolla 168,000 miles 1994 Volvo 850 165,000 miles 2003 Camry 12,500 miles |
#38 (permalink) | |
Registered User
#39 (permalink) | |
Registered User
Nice job Rando!
#40 (permalink) |
Registered User
Here's the modified circuit. Per the diagram, you could tap D1 at connector IC4 with an in-line tap to get a cleaner install. IC4 is behind the driver kick panel.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04 Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver Future Mods: 115V Inverter, Leather, Trip Computer Fix Last edited by rando; 05-09-2007 at 10:14 PM. |
#41 (permalink) | |
Registered User
Now you need to find a scrap yard and pull a replacement relay for your original. Almost any TOY has that relay.
__________________ '04 SR5 V6 4x4 Galactic Grey Mica. Delivered 03/17/2004. Link to my mod list in posts 7, 8 & 9 of this thread: http://www.toyota-4runner.org/showthread.php?t=21354 ____________ [__/[_[_\____\,_ L---L-L-L--0=*=0 `(o)_---(o)_--)_)`......... ``````````````````````` The battle begins at the end of your driveway... Game On! "Car!" |
#42 (permalink) | |
Registered User
#44 (permalink) |
Registered User
Question. My A/C wasn't working right, it came out cool instead of cold. I added more refrigerant and now it comes out COLD, but it doesn't work at times, I'm thinking about replacing the relay. Any input?
(BTW, rando, are you an electrician?)
'95 4Runner V6 4WD 128k 31x10.50 Goodyear Wrangler RT/S - 4.88 Gears - Sony HU - Polk dB401 - Sirius - iPod Touch (32GB) - Sylvania Silverstars - Air Box Mod - Mobil 1 Fluids - Used engine put in Apr-26-09, 109 k. '04 4Runner V6 4WD 93k Denso Iridium Plugs - Mobil1 Synthetic Fluids - Python Alarm W/Remote start - 265/65/17 REVO's 12/12/06 (47k) - Sylvania Silverstars |
#45 (permalink) | |
Registered User
If your relay fails, you'll get the flashing A/C light and the compressor will shut off (i.e you just get outside or recirculated air depending on your vent settings). If you push the auto button (or the next time you use your A/C), the system may work again, work for only a short while, or not at all.
No, I'm not an electrician by trade. I do have a CS/EE background though. Quote:
| Thread Tools | |
| Display Modes | Rate This Thread |
