Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > Problems & Warranty Issues
LinkBack Thread Tools Rate Thread Display Modes
  #16 (permalink)
Old 04-14-2009, 05:30 PM
NCSCOTT's Avatar
Often Ticketed Member
Send a message via Yahoo to NCSCOTT
Re: A/C light flashing
Originally posted by Ramidean
I have a 2006 with 32k miles and it started flashing. I have yet to check the part number but anyone here with an 06 run into the same problem? I would think that the part is different for the model year and it could've just gone bad? Dealers here in Germany are backlogged and I can't get an appt for at least 3 weeks. I may have to suck it up and replace the part myself once I've confirmed the part number.
Take it out. Tap it on a solid surface a few times and stick it back in. If it works it is the relay, no matter what part number you have.
04 4x2 Black SR5 V-6, PP 5W-20 Engine, M1 75W-90 Rearend, OEM V-8 Oil Filter, K&N FIPK, NGK Iridium IX Plugs, Scion T1807 HU w/ AUX input cable, Toyota All-Weather mats, Valor Exhaust Tip, Front Windows 35%, Silverstars.
08 4x4 Salsa Red SE V-6, PP 5W-20, OEM V-8 Oil Filter, K&N Air Filter, Optima 34R Redtop, Toyota All-Weather Mats, Valor Exhaust tip, Front Windows 35%, Silverstars & MTECs, Carbon filter removed, Daystar 2.5/1.5" Lift, 265/70 Revo 2s, SpiderTrax.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Registered users don't see this ad. Register today!
  #17 (permalink)
Old 01-31-2010, 04:04 PM
Registered User
The a/c light is blinking on my 2003 4runner as well. I just called the dealership and was informed that if I do need to replace the magnetic relay switch, the repairs would cost up to $1100 since it's no longer under warranty . That seems quite unreasonable! Are they serious??
  #18 (permalink)
Old 01-31-2010, 05:00 PM
NCSCOTT's Avatar
Check out this thread. Order the relay mentioned on page 6 from Digikey. I ordered 2. Less than $15 shipped. Arrived in less than a week. I broke off the center of 3 pins. It works perfect!!! Sure beats $1100!!! You can also try the tap on a hard surface trick. Mine lasted over 10 months longer that way. If it works it is the relay only. If it doesn't still replace the relay. You will only be out less than $10.
A/C light flashing??
See pic with pin broken off.
  #2     Report Post   IP
Old 07-10-2009, 09:59 PM
Sponsor
Edit/Delete MessageReply With QuoteMulti-Quote This Message Quick reply to this message
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
