Old 07-03-2006, 04:13 PM #1
snorto's Avatar
snorto snorto is offline
snorto is on a distinguished road
snorto's Avatar
Auto window roll down feature stopped working
Yesterday I disconnected the battery to wire up my driving lights on my '04 SR5. Today I had to reset the usual stuff - clock, radio presets, etc - but something else unexpectedly stopped working as well. The driver-side window no longer rolls up or down automatically. I can still roll it up & down by keeping my finger on the button, but the automatic feature doesn't work. What's up with that??? Is there something I can do to re-set this?
snorto is offline   Reply With QuoteReply With Quote
Old 07-03-2006, 04:40 PM #2
toto toto is offline
toto is on a distinguished road
Yes, you need to reset the one-touch features on the power windows and moonroof when you disconnect the battery. The windows use less power to close these days (so they're less likely to crush hands or fingers), so they need to "remember" where the closed position is.
To reset the driver's side power window auto-close:
1. Push down and hold the driver’s door power window switch to completely open the window.
2. Pull and hold up the driver’s door power window switch until the window closes. Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open/close” by pushing the switch briefly to the “DOWN” and “UP” positions.
To reset the moonroof one-touch operation:
With ignition switch in the “ON” position, do the following:
1. Push and hold the “TILT UP” side of the switch until the moon roof tilts all the way up and then tilts down slightly (approximately 10 mm [0.39 in.] at the rear).
2. Check for proper operation of the “one–touch slide open/close” and “one–touch tilt up/down” functions by pushing the switch briefly to the “SLIDE OPEN” and
“TILT UP” positions.
To reset the rear window operation:
1. Turn ignition switch to the “ON” position.
2. Push the back door power window switch to the “DOWN” side to open the window.
3. Push and hold the back door power window switch to the “UP” side until the window closes. Continue holding it for approximately 1 second.
4. Check for proper operation of the “one-touch open/close” functions by pushing the switch briefly to the “DOWN” and “UP” position.
The compass will also need to be reset if you disconnect the battery. Instructions for that are in the Owners Manual. You need to look at a map of the country to determine which zone you're in, and the instuructions are slightly different for 2003-2006 vs. 2007-2009.
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 07-03-2006, 07:17 PM #3
snorto's Avatar
snorto's Avatar
That did it. Thanks a million!!!
Old 07-30-2006, 10:35 PM #4
daleg13's Avatar
daleg13 daleg13 is offline
daleg13 is an unknown quantity at this point
daleg13's Avatar
Yes, thanks a lot. Same thing just happened to me. Couldn't find anything in the manual about it but I was sure someone here had seen this before.
2003 T4R V6 2WD SE
Current mods -
Silverstar headlights, Custom gutter guard grille insert, Blitzsafe IPOD adapter, '05 Scion H/U, 1" front seat lift, 12V powerport in center console
Future mods -
LED tail light bulbs, Leather seats w/ heaters, Dimming rearview w/ compass, LED turn signal bulbs, Rear spoiler?, maybe more...
daleg13 is offline   Reply With QuoteReply With Quote
Old 03-06-2009, 12:30 PM #5
Sharps Sharps is offline
Sharps is an unknown quantity at this point
Perfect! I was all jilted because I didn't know how to reset it in the rain 2 days ago.
Sharps is offline   Reply With QuoteReply With Quote
Old 07-28-2009, 01:22 AM #6
owen4runner's Avatar
owen4runner owen4runner is offline
owen4runner is an unknown quantity at this point
"To reset the driver's side power window auto-close:
1. Push down and hold the driver"
At what position does my ignition has to be in to do this? None of my Auto roll up/down on the driver side and rear windows seem to work after I disconnected the battery. Also the remote rear window roll down function does not work. I pushed down the "driver" button for a minute in key in/out/On/Acc/Start positions to no avail.
'04 Runner SR5, DeBadged, Rear bumper lens as Stop/Tail lights, EchoMaster Reverse Sensor, Hood Deflector, In-channel Window vent, Stinger Volt meter gauge, Scion Pioneer Head Unit, Front Lights clear lens protector. Hella Optilux 2500 Driving lights, Interior Blue LED lights, Waterproof Neoprene Seat Covers, Nokya Chrome Sports Pedals, Michelin LTX A/T2
owen4runner is offline   Reply With QuoteReply With Quote
Old 07-28-2009, 08:31 AM #7
Sorry. It looks like the post got truncated by the forum upgrade. I have fixed it.
Old 07-28-2009, 11:31 AM #8
Thanx. I'll try them on tonite. Another reason why I love this forum.
Old 02-21-2010, 04:38 PM #9
Cracka's Avatar
Cracka Cracka is offline
Cracka is an unknown quantity at this point
Cracka's Avatar
Thank you.
06 SE/V8/4x4
Cracka is offline   Reply With QuoteReply With Quote
Old 04-22-2010, 12:20 AM #10
T4RME's Avatar
T4RME T4RME is offline
T4RME is on a distinguished road
T4RME's Avatar
Please sticky this -
2008 4Runner Sport V6/4WD/White
T4RME is offline   Reply With QuoteReply With Quote
Old 04-22-2010, 01:51 AM #11
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
Done. Added it to the sticky list.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 04-24-2010, 04:53 PM #12
T4RME's Avatar
T4RME's Avatar
Did the passenger side have the auto up down as well or am I imagining that it did? I say imagine because I only had the 2008 for less than a week before I disconnected the battery and lost the settings...
Old 04-25-2010, 05:48 PM #13
Uneek's Avatar
Super Moderator
Super Moderator
Uneek's Avatar
The 4th gen only has auto up/down, open/close on the driver's and hatch window, and moonroof (if equipped).
The 3rd gen (all or the later ones) have auto for the passenger side window as well.
'06 Limited V6
Old 05-08-2010, 12:12 AM #14
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
I'm having a similar problem with my 4runner but following the steps doesn't seem to fix it. My AUTO light blinks constantly when driving, but never blinks when I follow the reset instructions. After the first reset attempt, I thought it was the LED, replaced the LED, didn't help (I know the LED wouldn't explain the auto function not working but I didn't think about it at the time and only noticed the blinking light). Bought a whole new switch assembly, connected it today, same thing. Tried following the reset after disconnecting and reconnecting the battery, the reset worked successfully for the sunroof and rear window, but I can't seem do anything with the drivers window. Any ideas what it could be? I tried the reset instructions posted here about 10 times before I gave up and posted this
gaterose is offline   Reply With QuoteReply With Quote
Old 08-30-2010, 04:12 PM #15
riverider riverider is offline
Banned
riverider is an unknown quantity at this point
Banned
Great helpful post.
riverider is offline   Reply With QuoteReply With Quote
Rear Window not Working?? okkin 4th Gen T4Rs 21 07-17-2020 09:13 AM
window Auto up/down feature kimboy 4th Gen T4Rs 4 05-12-2005 12:38 AM
'95 Rear window stopped working AznKlique 4th Gen T4Rs 2 03-22-2005 03:38 PM
98 back window wont roll up hamster_13 4th Gen T4Rs 1 01-29-2005 03:07 PM
Power Window Auto Switch 1fastrunner Problems & Warranty Issues 1 11-05-2003 10:24 PM
