Gx 470 - vsc trac, check, vsc off, slip indicator lights on...
snhrph
My wife called Monday morning: "All lights are on on the dashboard, what do I do?"
In the evening, I looked at the truck - VSC TRAC, Check, VSC OFF, and Slip Indicator lights were on. I disconnected the battery, let it sit, reconnected again, started the truck - lights came back. :ybrick:
The next day, I happened to be off, I took it to the shop. Fuel gauge was 1/4, so I decided to fill-up. Pulling into the gas station I thought - what are the chances that the gas cap is not tight :confused: It was not. Instead, it was broken!!! :wtf: do you have to do to break the gas cap? Stopped by Lee's Toyota in Queens, picked up the new cap for $25, and had my father-in-law read and wipe the codes.
Just wanted to share the info, and hopefully save someone a costly trip to the "stealer"...
