FS: Bilstein/OME Suspension in Gaithersburg, MD
What is the max lift you can achieve with this setup in the front? I have LC 7's for my rear so I will be around 3-3.5"
what is the max lift you can achieve with this setup in the front? I have lc 7's for my rear so i will be around 3-3.5"
2.5" is the listed max for the 5100 with stock springs. The 883s should bump that up a bit.
Sale pending ....
...but from Wheelers Offroad:
"Some customers are asking for these newer coils for heavier applications similar to the ones listed for the 2882 coils.
These are made from 16.5mm wire, have a free height of 375mm (same free height as 2881), and have a 590lb rate."
ADDITION: I'll be driving to VA Beach on 14 December if someone between the DC area and VA Beach wants to meet. Not sure what time I'm leaving the DC area yet...
Interested and in the Rockville area. Just need to do some research on 4th gen fitment and what rear spring I would need.
I know you said you wouldn't ship, but this is the exact setup I'm looking to do on my trail 4runner (~1" in the front to level it out and keep factory rear coils with new shocks).
Can you give me some more info on how the fronts are setup? I'm assuming OME 833 coils installed on the 5100s at lowest position? Do you have a picture of your rig with these installed?
Don't want to derail your thread, but I'm curious on this setup because it'd be cheaper than adjustable coilovers, as they'd be cranked down to ~1".
Thanks,
