FS: 4th gen V8 BNIB Gates Timing Belt Kit
blackoutt
Ended up in a time crunch and sourced local parts for my timing belt/water pump job and can't return this one so just passing it on to fellow members. Gates TCKWP298 The kit contains: Timing Belt, Tensioner Pulley, Hydraulic Tensioner, Idler Pulley, Water Pump, 6 Waterpump Bolts and Washers, 2 Gaskets (water pump and water neck but throw that one away and use FIPG), 2 O-Rings (water pump and water neck). This is a brand new unopened box. I can open it for pictures of the contents if requested. Retails for $157.78 shipped on amazon, so I'll undercut them a bit at SOLD.
Looks to fit almost any 2uz per the interwebs but you should double check before you buy.
Vehicle Fit
1998-2000 Lexus GS400 Timing Belt Kit with Water Pump for V8 4.0L Gates TCKWP298
2001-2007 Lexus GS430 Timing Belt Kit with Water Pump for V8 4.3L Gates TCKWP298
2003-2009 Lexus GX470 Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
1998-2000 Lexus LS400 Timing Belt Kit with Water Pump for V8 4.0L Gates TCKWP298
2001-2006 Lexus LS430 Timing Belt Kit with Water Pump for V8 4.3L Gates TCKWP298
1998-2007 Lexus LX470 Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
1998-2000 Lexus SC400 Timing Belt Kit with Water Pump for V8 4.0L Gates TCKWP298
2002-2010 Lexus SC430 Timing Belt Kit with Water Pump for V8 4.3L Gates TCKWP298
2003-2009 Toyota 4Runner Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
1998-2007 Toyota Land Cruiser Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
2001-2009 Toyota Sequoia Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
2000-2009 Toyota Tundra Timing Belt Kit with Water Pump for V8 4.7L Gates TCKWP298
