02-03-2008, 07:53 PM
#1
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
Tweeter To 3.5" Coax Swap
Just did a little speaker mod today, borrowing from something that I had done with my Grand Cherokee (which had an almost identical speaker setup) prior to getting my 4R. I took out the factory mid/tweets that are in our doors and replaced them with a set of Infinity Kappa 3.5" coax's that I had kicking around. This may not be for the faint of heart for some as it required me to do some denting (deliberate metal bending) with a hammer to get it to work, and mild cutting to the factory tweeter bracket. I only did the passenger side so far (getting dark and the Big Game is on), but I will do pics and a followup when I do the other side. So far I gotta say that this is a HUGE difference in sound. Fading back and forth from L to R, the factory setup sounds muffled now compared to the strong midrange and high output that I now have. Only downfall I noticed is that the replaced speaker distorts a little at max volume, but I can surely attribute this to it being 4ohms vs. 8 for stock, and the magnet requires a lot more juice to thump, but at 60 and below it's great. This I hope to solve when I get the new Kenwood DNX8120 coming out in March. I plan to have the front 3.5"ers run by the head unit with a set of bass blockers on them and have the door speakers replaced being run off of a seperate amp.
To be continued....
__________________
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
02-04-2008, 04:16 PM
#2
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
__________________
#3
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
__________________
02-04-2008, 05:07 PM
#4
Member
Real Name: Brad
Member
Real Name: Brad
WOW! Very nice. That looks great! I see what you mean by "denting" now...
__________________
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
02-04-2008, 11:00 PM
#5
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
Thanks! Just got home from work and spent some time listening to a variety of music, and I just can't believe the difference this made so far. The soundstage now seems like it's more level with my head whereas before it seemed very low. I went ahead and put bass blockers on that I grabbed at Best Buy that are rated at 300Hz. This seemed to round off the install nicely as I did this with drivers side this time and listened to the difference between it and the pass. side that I did yesterday without it. With them both on they sound great. Now hopefully these will sound even better when I get them hooked up to the replacement headunit and new door speaks run off of a seperate amp.
__________________
02-07-2008, 06:57 PM
#6
Member
Member
very nice! did u use the same holes on the factory tweeter bracket to mount the 3.5 inch coaxial?
__________________
2004 4runner sport edition 4x4
02-07-2008, 11:12 PM
#7
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
No I had to drill new holes with sheet metal screws slightly offset to the factory holes. The 3.5" basket is just a tad bigger than the factory speaks.
__________________
12-07-2008, 11:43 PM
#8
Member
Member
is this with a basic speaker system or the optional jbl synthesis
__________________
2008 Sport Edition V-6 Titanium Metallic 2WD:
LiquiCell Black Leather Seats, SpiderTrax Wheel Spacers, 16% Tint over Factory optional tint, Single-in-Single-out 40 Series Flowmaster, iPod Intergration Kit, J.A.'s Foglight Mod, 285/70R17 BFG MT Km2
Suspension *UPDATED**Front*Biltstien 5100 Adjustable Shocks, Light Racing UCA's and OME 886 Springs, *Rear*OME 60004 NitroCharger Sport Shocks and OME 896 Springs
The Silver Bull
12-08-2008, 04:55 PM
#9
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
This is with the basic system, but will work either way. You'll definitely love the improvement. Just be sure to get the bass blockers.
__________________
02-20-2009, 01:40 AM
#10
Member
Member
does the bass blocker prevent bass from coming through the tweeter or just block bass all together?
__________________
05 t4r sport
unfortunatly 2wd but that dont stop me
took off my running boards
audio:
10" boston acoustics G-5 subwoofer
10" boston acoustics tunable radiator
custom sealed box
boston acoustics amp
02-20-2009, 06:14 PM
#11
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
It blocks the unnecessary frequencies from overpowering the speakers. You have the 6x9 in the door to take care of that.
__________________
03-03-2009, 03:43 PM
#12
Registered User
Registered User
Great Job on the installation. Does the tweeter run on a seperate channel, or does it tie into the 6X9 like seperates do?
03-03-2009, 05:14 PM
#13
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
The factory speak/tweet I believe had a resistor on it (bass blocker) but don't know where the heck I put them to double check. So I'm assuming, almost positive, it was on the same channel. Otherwise it works great!
__________________
05-16-2010, 04:05 PM
#14
Junior Member
Junior Member
Mike, nice post from a couple years ago. How much room would you say there is between the tweeter and the grill. Would there be enough room to use a couple washers to lift the speaker up on the bracket a little to make it less necessary to dent the frame. How much room is there without having the tweet in physical contact with the grill.
Do you know the exact model of those Infinity's?
I was thinking that an extra bit of spacing on the speaker combined with a slightly less deep speaker might negate the need to dent the panel.
__________________
'05 SR5 2WD/V6 white/stock
05-19-2010, 05:00 PM
#15
Senior Member
Real Name: Mike
Senior Member
Real Name: Mike
I see that you have an '05. A buddy of mine with an '04 did this without me around and said that he didn't have to put in as much work as I did (no denting). As far as the door panel grill to tweet goes, you will have to dremel off the round plastic flashing on the grill to prevent it from rubbing the new coax. You'll see what I'm talking about when you have it off.
As far as the type of speaker, I'm not sure exactly. Just that I know they're Kappa's made before Infinity went to using 2ohm speakers. I think they've gotta be going on 4-5 years old now, and only been using them for the past 2!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
