Snowjunky runner build
snow junky
97 4runner 3rzfe 2.7L 5speed 4x4.
got this truck 100% stock, so far mod as of 5-1-15 are:
2in BL
FRONT-skyoffroad french shackle sas swap kit rancho leafs d44 5.38 gears and locked
rear- lc 9 wraps with spacer
chief wide track dana 44 flat top knuckles sky HD histeer arms 5.38 gears and locked
t100 oil pan kit with turbo oil return line
5-35x12.5x15 dick cepek fcll
T3T4 57trim turbo 7psi
piller gauge pod-AEM wideband, boost
255lph fuel pump
wide band AF gauge, vair compressor gauge,vac/boost gauge
York 210 long stroke compressor oba 5gal air tank
105 amp GM alternator
Viper 2-way paging alarm with dual sirens and tilt sensor
GPS tracking system
4 Train horn blasters kit
trail gear rock sliders
trail gear crosmember/tcase armor
2-55w hid offroad flood lights
safari roof rack
4-55w hid hella offroad
oversized battery 9/13
magnaflow muffler
toyota mini header
tacoma antenna
Jvc in dash nav w/ rear camera
15/8 procomp 52s
front and rear pro comp shocks
marlid HD clutch kit
rear detroit trutrac 5.29 gears
rear Heavy duty pinion flange
removed front sway bar
rear sway bar drop
rear extended steel braided brake line
tubed firewall (no rub on bumpstop lock to lock)
winch under oem bumper
Smittybilt XRC 8 Winch
deck plate mod
custom intake
K&N filter
rear cree led lights in bumper
bed liner rear wind diffuser and rocker panel
cobra cb with dual pa speakers on amp
800w built in power inverter
extra cig lighter ports rear and front
kicker door speakers
two JL tens
led gauge cluster/dash/lic plate
2000 4runner clear headlight 100 ultra white bulbs
super bright led map/dome lights
extended front diff breather, rear breather goes to inside fuel door
IMG_0489.jpg~original
IMG_0493.jpg~original
IMG_0401.jpg~original
IMG_0402.jpg~original
IMG_0253.jpg~original
IMG_0053.jpg~original
IMG_0040.jpg~original
IMG_0326.jpg~original
IMG_0255.jpg~original
IMG_0139-1.jpg~original
IMG_0136-Copy.jpg~original
IMG_0038.jpg~original
IMG_0465.jpg~original
IMG_0417.jpg~original
ubugave6.jpg~original
ADD Switch
Could you post up some details on your ADD switch modification. I'm going to go research it now, 2wd low would be nice!
Mike
only 230,000 miles 165psi on all cylinders
preventative maintenance (mostly):
new (battery oversized)
new alternator (GM high amp)
new fuel filter
new spark plugs/ wires
new headers (mini header)
new catalytic converter
new starter
new exhaust system header back
new UCA bal joints
mt90 synthetic in front and rear diff. transmission/transfer case
flushed cooling system
flushed brake system with synthetic brake fluid
new synthetic power steering fluid ATF
New ps pump with cooler
electric flexalite fans
new front tundra brake calipers
new brake pads front and rear
new steering rack
NEW cv axles left/right
new seals (oil pan, rear main, valve cover, exhaust)
adjusted valves
new marlin clutch kit
new marlin shifter bushings
new belts
new k&n
Replaced lift hats shocks
Led headlights
Oil filter housing seals
170f thermostat
190f fan on switch
250f safety alarm buzzer
New radiator with hoses
much more im forgetting
Mike
ya its one of my favorite mods. FREE too
i had a wiring diagram of how i did it. idk what i did with it tho...
basically all i did was wire a relay to the vacuum solenoids.
I have a lot of respect for you, building a 4 cylinder. Everyone else has a V6 including myself. BUT, I was looking to get a 4 banger Tacoma, I couldn't pass up the 4runner, though. Subscribed, great looking rig!
ya i got a deal i couldn't pass up. i really like the 4banger plenty of power to pull a small boat up hills and the 2 extra mpg helps
here are pics of what i did, cant see much tho,
IMG_0496.jpg~original
IMG_0497.jpg~original
IMG_0498.jpg~original
If you could try and find that wiring diagram, or maybe just follow the switch wiring back and take a couple pictures, you would be...
LEGAND... wait for it... DARY
IMG_0028.jpg~original
IMG_0032.jpg~original
got some 285x75r16 for the street. rpm isnt too high going 65mph. up hills and around town they help mpg (with 5.29s)
<BR>
IMG_0295.jpg~original
got some 36x12.5r16 super swamper radial tsl for the snow
headbang.gif~original
IMG_0299.jpg~original
394048_2419000154432_1234253301_32129405_1978897802_n.jpg~original
Maybe never. I might go with 35/13.5/15 toyo open country mt. The swampers are too thin for the snow. Waiting to sell the swampers
How can the swampers be to thin for the snow? I my experiance the thinner tire is better in the snow. First off you get more contact with the pavement with the thinner tire. The wide tire seems to ride on top of the snow giving you less control. Tread helps but still the more contact with the pavement the better.
The truck looks great.
Can you post some additional pictures of the winch set up. I'm curious how you did this.
I'd love to add a winch later on down the road.
junr
your completely correct, i have done tons of research about it (thin tires will have same contact patch as wide for same weight and psi) however thin tires dig down to the solid ground, but were i go thats a good 6ft+, so it will just dig till my frame floats.
So what your saying is you want the floatation not the traction!! Maks sence to me!
Like the build will follow this one.
IMG_0505_zpsd12349c8.jpg~original
test fitting it.
think im going to mount coils to the back of the york on the mount i fab up, i also think im going to weld a vbelt pulley up to the crankshaft pulley.
any ideas?
Can you post up some pics of your truck showing the winch setup ? Maybe a couple from a little distance? I like that idea.
