Paragon1
Member
UPDATE: Had to get rid of photobucket, what a horrible service that was. Swapped to IMGUR, but holy lord the photos are huge now, but they still get the point across. Now, as for the lights. I swapped up to the 6200K because I wanted less yellow. Still 100% satisfied with no problems after even 2 years. If there's one critique, the seals they put on the cables that come through the dust caps should be of a size that match one of those circular drill saws to prevent moisture from getting in. It hasn't been an issue, but the potential is there. Glad to see this post is hanging in there.
Had a talk with Steve from XenonDepot regarding the output of the LED lowbeams in projector housings, but first let me say how impressed I am by their service, truly a class act.
Anyway, in my opinion the projector housings werent suited for LED bulbs that only have one diode per side, they're more for open housings such as the kind on the pre-refresh models. They're still brighter than stock, but the volume of light left a bit to be desired especially if the road is wet due to the blue-ish color temp.
So I decided to go with the 4300k HID kit. Install took 20min. Utilizing a saw-bit on the drill to make the perfect size hole in the caps to fit the grommet that the ballast wires run through, and the 3M adhesive for the ballast components though I'll probably do a more permanent mount after I move.
Haven't had time to do night pics just yet; but let me tell you, these are the way to go. There's a bit of yellow in the beam, but Steve told me that they'll get a bit more blue after they burn-in at about 100hrs. These combined with the LED fogs give an impressive spread. Super happy with this upgrade, as well as all the advice from XD.
I'd say I have the LED lows for sale, but instead gave them away to a fellow forum member (PopSmith) for helping me with my front shock install (took 3hrs). Seemed like a fair trade.
Here's a daytime side by side of the HID vs LED, more pics up tonight. Cheers.
So here's the breakdown. On top is the 4300k HID, Middle is the LED lows, bottom is sylvania ZXE. So far I haven't been flashed by other drivers, but admittedly I'm in town so the effect isn't quite as extreme as it would be on empty rural areas. Worth every penny. If you're wanting to upgrade, HID is my recommendation if you have projector beams.
