Official T4R 18" All-Terrain Tire Thread - Help Wanted!!
Which A/T Tire for the 18" OEM T4R Rim???
  • BFG A/T KO LT265/65R18 (31.7")
    Votes: 21 26.3%
  • BFG A/T KO LT285/65R18 (32.7")
    Votes: 14 17.5%
  • Terra Grappler 285/60R18 (31.5")
    Votes: 8 10.0%
  • Terra Grappler LT285/65R18 (32.52")
    Votes: 12 15.0%
  • Discoverer STT LT275/65R18 (32.32")
    Votes: 10 12.5%
  • Geolander A/T-S 275/65R18 (32.1")
    Votes: 3 3.8%
  • Geolander A/T-S 265/70R18 (32.6")
    Votes: 4 5.0%
  • Other - (Please list in thread)
    Votes: 8 10.0%
  • Total voters
    80
ProMed
Ok here is the deal, as many of you may already know finding 18" AT tires is no easy task. Most of the brands are a no-go. I have the OME lift installed and have been having a tough time picking out the right tires for the 18" OEM limited rims which are 7.5" wide. I will most likely go with the 1.25" Spidertrax spacers as well.
The truck will be used during the week doing a lot of highway miles traveling between my sales accounts. With this in mind gas mileage and road noise carry some importance in my decision. I don't want a mud-terrain but having a solid off-road tire that won't leave me stranded is important. After selling my old jeep I would still like to have something to get back into the woods and mud.
I am not really wanting to trim very much for 285s but they are on the list just in case since the BFGs are a little smaller than a full 33". BFG ATs were on my last Tundra so I am familiar with their characteristics. However the 285/60 Nittos seem very interesting since they aren't as tall as a 285/65, but are nearly as wide. My only concern is trying to install them or the BFG 285 on a 7.5" rim. Is this a definite no-no since they recommend a minimum of 8"??
Any opinions would be appreciated! :beer:
Here are the current front runners:
-BFGoodrich A/T KO LT265/65R18
(31.7" Overall Dia.) 7.5-9 rim (~10.7 wide) 16 tread depth
-BFGoodrich A/T KO LT285/65R18
(32.7" Overall Dia.) 8-10 rim (~11.6 wide) 16 tread depth
-Nitto Terra Grapplers *285/60R18 *-denotes heavy load(??)
(31.5" Overall Dia.) 8.0-10 rim (~11.54 wide) 13.1 tread depth
-Nitto Terra Grapplers LT285/65R18
(32.52" Overall Dia.) 8.0-10 rim (~11.22 wide) 16.5 tread depth
-Cooper Discoverer STT LT275/65R18
(32.32" Overall Dia.) 7.5-9 rim (~10.98 wide) 18 tread depth
-Yokohama Geolander A/T-S
**Coming Soon**
275/65R18 (~32.1" Dia.) & 265/70R18 (~32.6" dia.)
BFG A/T KO
Since nearly half of the tires listed may not work due to the 7.5" rim, if any of you know of any other interesting 18" A/T tires please post them up!
:guitar2:
I have michelin 275 55 18's on my trd 18" wheels. If your doing a lot of highway miles, stick with the 265's.
285's will add to the rolling resistance, and the tread has to do more work to displace the volume of water when it rains.
But, if you want that wide track stance, and can minimize the amount of trimming you have to do, go for the 285s.
Just my 2cents.
I am interested in the outcome of this poll for my own reference as well. I still have quite a bit of time before I will be replacing the stock rubber, however, it can't hurt to do some research in advance.
I like the tread pattern of the Coopers, but I think they would be fairly loud at highway speeds. For an AT tire, I think the BFG's are a good choice. Many people have run these tires and had good results.
I have no experience with either of these on my 4runner, however, I have run the BFG's on other vehicles and they have performed quite well.
MAC4Runner said:
Given your job I'd go with the 265 Nittos. I love mine both on and off road. :bigok:
For the 18" rim the only availability is the 285/60R18 and 285/65R18. The problem is that they both recommend an 8" rim or larger and the oem rim is 7.5". It would be interesting to hear from someone with experience if this is a definite deal stopper or if it is ok to run on the smaller rim??
Opps.. I meant the 285/60. :bash:
285/65R18 wont fit according to 4Wheelparts- even ordered and tried to install them and they said no go. Any suggestions or answers why would be a big help because these are the ones I would like to use also- I'm putting them on 18x9s with a Revtek and 1.25" bodylift.
They fit- 4wheel parts was afraid to cut anything. It required only minor trimming of the well liner- no visible cutting- even of the corner edge of the well! Ride great! I love em- ride looks meaner than ever!
Wow it's a thread revival! You're not going to get those rubbers to work on your 18"er's. The 7.5" wheel is just too narrow when these tires are coming with a narrower sidewall which doesn't allow enough flex for it to sit in and create a proper bead with the wheel. The tire manf. list the wheel width ranges for a reason, however I'm sure they probably also do provide for a margin of safety as well. If the 285 is a no go, look at the 275's, they're most likely to be able to work.
Yes, I went with the 275 Coopers on my stock 18 rims. Link to pics is in sig.
STT's, why use 265's when you can fit 285's. Plus they look badass compared to your other choices. I like the looks of the Goodyear MT/R's also, not sure if you can get them in 18's though.
I went with the STTs in 275 because I could fit a full-size spare.
Update: Well after the 1.25" body lift , 285/65/18's fit without a problem!- even kept the mudflaps on- just needed to cut about 3" off the bottom inside wheel well liner but not the corner of the body. Looks really good. I'll post pics when I can.
here is a bad shot from the phone and some digital editing of the background.
285/65/18's on Procomp 7028s. No spidertrax. Revtek 3" and 1.25" bodylift. Very minimal trimming of front lower liners.
Sweet! I love black wheels!
Do you know the offset or backspacing of the wheels?
Re: Noise with STTs?
magnumfan said:
Looks GREAT - hows the nosie at highway speed with those lugs?
j
I am putting in frequent 200+ mile days with the STTs, below is a quote from the thread in my sig:
The tires are certainly not made for long commutes and I have to assume they will no doubt be louder than almost any AT tire. That is why I sprayed the wheel wells with the rubberized coating! However they are not annoying loud in the least bit in my opinion, even before I sprayed the coatings.
Hope that helps!
