Sulfur (aka. Rotten Egg) Smell on '03 4Runners
Thai
Elite Member
Sulfur (aka. Rotten egg) Smell for '03 4Runners
Hey all,
This was a question of PWRHungry on this board. I thought i would try to clarify the situation a little bit:
There has been much discussion about this "sulfur smell" on other boards. Basically, Toyota claims that this is from the quality of gas you put in your truck. In other words, try a different gas station/brand. Or move to California (stricter gas & emission controls), where very few owners (if any) have this problem. Toyota also advise to be more mellow in your driving habits (avoid hard acceleration).
The theory for this smell is that due to clean emission standards (ULEV) set by Toyota (and other car companies) and that many gas companies have not caught up with these standards, there are still large amount of sulfur in the gasoline. This smell is most noticeable when you accelerate hard. Also, if you leave your windows down, the smell will hit you hard.
Toyota currently has NO plans to make any changes nor has any fixes for this. In it's defense, OTHER car manufacturers also are getting this complaint.
Of note, the 3rd gen 4Runners usually do NOT have this rotten smell because our emission standards are lower (LEV instead of ULEV); apparently this smell is most noticeable in vehicles with ULEV rated-catalytic converters.
I have smelled this occasionally on my '02 4Runner (LEV-rated). It is normal to smell it once in a while; however, it looks like the '03 4Runner is more susceptible to it.
Hope this helps.
Here is the TSB about the "sulfur stink":
TSB EG003-03
Introduction:
Some owners of Toyota vehicles may experience a sulfur like or rotten egg odor from the exhaust system. Sulfur is a natural component of crude oil from which gasoline is refined and the amount of sulfur can be decreases through the refining process. The amount of sulfur in fuel in CA is regulated, however gasoline sold in other states can have substantially higher sulfur content. Sulfur content also varies considerably between gasoline brands and locations.
Applicable vehicles:
All models
Repair procedure:
A sulfur odor emitted from the vehicle tailpipe does not necessarily indicate that there is an issue with the engine’s condition, but is most likely directly related to the fuel. If the vehicle is exhibiting an excessive sulfur odor, the following checks should be performed:
If the MIL light is ON, check for DTCs and repair as necessary
If no trouble is found after performing the above check, recommend the customer try a different source of fuel.
Replacement of oxygen sensors, air/fuel ratio sensors or catalytic converters will not reduce the odor and therefore will not be considered warrantable.
I've got an answer for that smell. Cut the cats out and replace them with pipe. And remove the rear "cat o2 sensors" and hook a O2 simulator to the harness. Done. No smell. No engine light. More HP. NO problems. :D
Here is a map of Reformulated Gasoline (low sulfur content):
Over the next few years, the "reformulated areas" will expand. However, this is very costly to the oil companies...thus, it is not an overnight change.
Just a note: I have not heard of one case of sulfur smell from California 4runner owners.
As far as i know, the newer engines do not suffer from any significant power loss with the reformulated gasolines.
97
My 97 has been doing this, but recently the sulfur stink got pretty bad. I was going to have it taken in to get it looked at... but the dealer said there is nothing that can be done.
So does this mean I am going to be forever driving around a car that stinks like rotten eggs? there's absolutely no solution / possible other problem?
-Sarah
a matter of gas
Is it a matter of what gas you use? would a different type help the problem?
My dealer said to go around and try different gases and see which one worked the best... this is so strange?
I got some gas from Toms Brook, VA last night and so far so good with it...
Yeah, that's what Toyota is telling people...try different brands. However, most of the time, this does very little according to many '03 owners. (See map above.)
Likely, YES. Toyota has made no changes to it's catalytic converters. Toyota's TSB clearly states that they do not plan on doing any changes...it's up to the oil companies to change.
Wow. I thought that the smell was coming from outside somewhere. I have noticed the smell a handful of times. I didn't even think that it was coming from my truck. :confused:
I walked up to a running Sequoia last night and it stank at idle. Wonder how long until Toyota is embarrassed into doing something about it? (not a chance the oil companies will)
Unfortunately, it's affecting many other brands (almost all i think) too.
My '03 stinks so bad I (almost) wish I hadn't bought it. I've been through the fight with the local dealer and Toyota customer service. Tried many differant brands of gas, etc. with little luck. After pointing out to my friendly service advisor that I'd tried differant gas, and that my wife's '03 Subaru did'nt stink when it ran the same gas, he admitted that it was just the super clean exhaust standard they were achieving. I even had the state DEQ test the exhaust output... zero% CO, and 12 ppm hydrocarbons. So where do I fint the o2 simulator for the rear cat...
In response to Thai
I'm from Southern California and I've been wondering about the sulfur smell for a while now :(. Maybe I'll try switching up to Union 76 100 octane:D
If you don't mind paying around $5/gal then the refinieries (not the producing oil companies) would be glad to produce as close to 0 sulfur gas as they possibly can.
The fact is for oil to go to the refineries from the oil companies the sulfur content of the crude has to be very low to even be sent to the cracker for gasoline production.
If you think about it, the fact that more owners are smelling sulfur out of the exhaust is not a good thing - i.e. acid rain (H2SO4) production. The manufacturers are required to eliminate CO2 production which really does not affect the environment at all - sulfur affects the environment.
Someone asked if this affected the 04's as well. The answer is yes, although the only time I have ever smelled it is after my morning commute to work, right after I leave the interstate and sit at a redlight, then it is rotten egg city.
