FS: Tundra Front rotors - drilled - Brand New!!
midnight runner
I have a pair of Tundra rotors here. They are drilled, with a gold anti-corrosive coating. You won't see any rust on these rotors!
Use these for a 4runner upgrade to the Tundra calipers. Asking $130 obo shipped for the rotors.
Rebuild tundra calipers with pads are also available. $330 FIRM for the pair.
Brand New SS lines also available $70 FIRM.
I might be interested in the whole lot (rotors, calipers, pads - might need the SS lines too).
How much for the whole lot shipped to 45248?
$425 Shipped with pads and the Stainless steel lines.
$375 Shipped with pads and w/o the Stainless steel lines.
The pads will be loaded into the calipers already. Calipers are rebuilt with all new seals, pistons, boots, and hardware in addition to having a corrosion resistant coating. Sample pictures of calipers. Not actual calipers to be shipped.
or
So the lot has everything needed? or will you need other stuff to make this work? What affects will the larger rotor, and calipers have on the braking system?
How much for everything to 32507
You'll need brake fluid, some elbow grease, and wheels that fit over the brakes. Everything else is included.
With the larger rotors, you'll gain more heat capacity. The pads will have more bite than the OE Toyota pads which means the brakes will be more responsive. Stainless steel lines are an upgrade over your stock rubber lines which expand when under pressure. With the SS lines, your pedal will feel stiffer.
I'm not sure of the fitment of these brakes on the Gen 4's.
