perfect...now i wont have to start a new thread...i had some questions on this same setup.... i have an 08’ with XREAS and this weekend ill be purchasing a set of 4 FJ springs/shocks. [$100 from someone locally] I want to keep the XREAS so do I just use the springs and sell the shocks? Yes. Doing this I will not lose the XREAS correct? Correct. Also when I decide on which level kit to get I get the one made for the 4runner correct since im only using the FJ Springs? Well... 4Runner or FJC won't matter as far as spacer lifts are concerned even with XREAS. You can mix and match as desired. Once you study it you'll see most of the part#'s match up between the two vehicles.
The FJ springs will give me approx a 3/4” lift right? Yes. Combined with the wheel spacers this will allow for larger tires when I am ready to purchase in October , I have 18’s so im wondering how big I can go? 275/65/18 without significant trimming and you can still carry a full sized spare. Search for the user ProMeds T4R of the month post for pics. Spaceman jammed the same sized tire on with no lift. He made a good post too.
