Am i the only 4runner owner getting 11mpgs?
2004TR4-SR5
As the title says...i am seriously getting 11 mpgs..does this make sense to anyone one? could the fuel filter be bad...someone please help....its pretty bad when my 2001 cammed camaro ss gets better gas mileage then my v6 4runner..wouldnt you guys agree?
Do you drive your 4runner like i would drive your camaro, foot through the floorboard? :zoom:
i drive this thing no different the i did when i was getting 400 miles on a full tank..i do 70 maybe 75 on the highway
Hows the power output? any CEL's. How many miles? any major maintenance performed recently? The more info the better.
J
That is way too low for a V6.
This is a good website as it uses modern methods to calculate gas mileage. and your car should be around 15 mpg or there abouts. Toyotas rating is even higher than 15 mpg. Even a Land Cruisers according to this website gets 12 MPG in the city. the big Land Rovers do better than 11 mpg in City
http://www.fueleconomy.gov/
Does the car run smooth?
Have you done a tune up lately
The V6 uses regular spark plugs (ie not iridium plugs), so it needs to be changed every 30,000 km or so.
Are you calculating the gas mileage by hand. If not, do a manual calculation, maybe your vehicles display is off. Manual calculation is more accurate.
its in tip top shape no cels no problems...but i do have iridium plugs...could that be the problem?? i have an iphone app that calculates it for me and it says 11 while my computer on the truck says 14
Huh? That is your problem. why are you using your iphone app to calculate it. It's probably based on GPS location, etc, which is not as accurate as your speedometer reading. Why didnt you mention your truck says 14. 14 sounds about right?
Calculate it manually by doing this if you want accuracy:
1. Fill up the gas tank completely
2. Reset the odometer to zero
3. Drive a few days or few hundred miles.
4. Fill the tank again, note the amount of gas you put in.
5. Look at the odometer reading
Now simply take the miles divide by the gas you put in. Miles/gallons.
thats not the problem because i used to get almost 400 miles on a full tank now i barely get 270 miles...the app is actually perfectly accurate..cause i just hand did it and it came up exactly what its telling me
you do it....162 miles filled up to 13.639 gallons = 11.88 mpg
note..my avg is 13.72 but that is still low
also that 162 miles was from a full tank to a 1/4....now tell me something isnt wrong here?
Yeah, bit on the low side. The website is saying around 15mpg and yours is 13.72 so a difference of 1.28 miles for every gallon. At least now it's closer to what it should be. Are you driving within the speed limit?
Not to be rude but if a 4th Gen V6 is getting 12 mpg, it is NOT in tip top shape. Something is def. not right. Clogged cats or intake could cause it, but that would also mean a significant loss in power. Hows tire pressure? Sounds dumb but if all the tires are very low in pressure, that could hurt mpg too. How many miles are on it?
2 or 4wd? Are in 4hi? What kind of tires? Are they inflated properly?
Try resetting the ECM by pulling the breaker for a minute or two.
You aren't using E85 are you:lmao:
If everything is good and you don't have your 1000lb gold stash riding around in the back I'd look at cleaning the throttle body, removing (or replacing) the HCF filter and I won't rule out plugs yet. What type of plug do you have? Air filter good? You aren't trying to run 10w-60 oil, are you?
:cheers:
tire pressure is perfect..they are firestone destinations at's but this started before the i put those on...i have absolutely no loss in power...it will move when i need it too...im sorry but winter gas/cold weather and not driving the speed limit will not take me from 400 miles on a full tank to not even 270 miles on a full tank...
here are pictures to prove my point...
these pics are around the time when i first had the truck...getting about 400 miles
look at the range, then look at my trip...do the math..
<a href="http://s791.photobucket.com/albums/yy196/ToyotaSS/?action=view&current=Picture011.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy196/ToyotaSS/Picture011.jpg" border="0" alt="Photobucket"></a>
<a href="http://s791.photobucket.com/albums/yy196/ToyotaSS/?action=view&current=Picture012.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy196/ToyotaSS/Picture012.jpg" border="0" alt="Photobucket"></a>
now here are pictures of it now...once again...look at the range, then look at my trip...do the math
<a href="http://s791.photobucket.com/albums/yy196/ToyotaSS/?action=view&current=IMG_0449.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy196/ToyotaSS/IMG_0449.jpg" border="0" alt="Photobucket"></a>
<a href="http://s791.photobucket.com/albums/yy196/ToyotaSS/?action=view&current=IMG_0450.jpg" target="_blank"><img src="http://i791.photobucket.com/albums/yy196/ToyotaSS/IMG_0450.jpg" border="0" alt="Photobucket"></a>
8.5% more gas, that's it!
You are confusing everyone with your 11 MPG title. You said the average is 13.72 so it's not too far from the 15 mpg that it should be. And the 15 mpg is also based on the original stock 4runner. And maybe they tested it with a standard temperature and does not take into account speeding. So again, your is 1.28 miles less than the tested 15 MPG for these V6's. So factoring in the fact that you speed a bit, and your tires may take up more gas than original, and the colder temp, etc. you end up losing 1.28 miles per gallon.
Man, you need to read up on how speeding kills your gas mileage, as much as 25-30 percent. 1.28/15 = 8.5% more gas. So, you car is using 8.5 percent more gas. Just speeding alone can cost you 30 percent more gas, and we haven't even started talking about the colder weather.
Also, take into account, if you do a lot of small trips, that brings down your miles per gallon.
So now, if we look at the numbers again, your vehicle is taking 8.5% more gas than the posted MPG from the website. nothing to be alarmed about.
In short, considering you speed (or may not go the posted speed limit), cold weather, high rolling resistant tires, etc, it's not surprising to your 4runner will consume more gas.
you really must not be understanding what i am saying....i used to get 17-19 mpgs between highway and normal driving..and its mostly highway and now i am down to 11-14 mpgs...when i got 17-19 i would get, to be exact..375 miles on a full tank of gas...now i am at 282 miles on a full tank....dont expect me to believe that everything you just listed above is gonna cause me to lose almost 100 miles...once again im sorry..speeding is not a big factor..i drive fast in my camaro and it gets exactly what the car is supposed to get..even when i drag race it
"speeding is not a big factor..i drive fast in my camaro and it gets exactly what the car is supposed to get..even when i drag race it"
Based on your above statement, I now know how little you know (sorry, but do your research). I'm finished with this thread. Outta here. Not possible to help someone that denies simple truth.
ok ill go with you stupid theories and believe me doing 70 on the highway and winter weather will cause me to lose 100 miles...i laugh at people like on who actually go by these theories...see the funny thing is that i drive this truck no different then i did when i first bought it..you cant sit there and tell my 11-13 mpgs is normal...i know people with Sierra's and silverados and tahoes getting 13 mpgs...that sounds right to you? that im getting the same mileage as 8 cylinder suv's and pick ups?
lol, the fact you think these are my theories shows how little you know. Educate yourself. please. first you post something absurd like 11 mpg and then you say you calculated with your iphone, then you said you calculated it manually and got 13. something mpg, then you said it is ready 14 mpg on the display and now you are saying your getting 17-19 mpg, get your facts straight before you post and be more intelligent about it. And dont be an idiot speeding around, you might end up killing an innocent person.
next time just say:
i used to get 17-19 mpg and now i get 11-14 mpg and nothing has changed, my driving habits the same, etc, etc.
Thats all you need to say,but that would be too difficult for you to put together
hahaha..i cant even say anymore to you...all i can do is laugh..and if i was in front of you id laugh in your face..you obviously dont understand what you read
