Factory rear leveling system
allirunner
Does anybody want to get rid of their factory rear leveling system. Also, does anybody know where I can look up the components to purchase the system if I can't find a used system?
Thanks!
2005 4Runner Limited 4x4 V8
Buy the Toyota repair manual. I think book 3 for the 2005 has the suspention. Be cautions however, there are a lot of components to add this system.
Can someone take some pics of the factory (OEM) levelling system components? Do they work on the same principal as the aftermarket systems (airbags inside the coils?)
I thought about adding this system and priced out all the parts from the diagram on partznet (about $2200 in parts). Same concept, airbags in the coils with air compressor and a tank. There are also two level indicators to automatically level out the system based on weight in the truck and some electronic components. Aftermarket will likely not have automatic sysem but rest will be the same. Now the one thing I'm still unclear on is how this works with XREAS.
Just to save work, would you care to share the parts list you generated? Especially the airbags, compressor and tank (for a partial stock system without the auto features.)
Thanks in advance.
Thanks in advance.
The list is in book three repair manual which I don't have here, I will see what I can do later tonight.
There are no springs on the factory system, just air bags. Also the dash gauge (indicators in the tach guage) is different. I can snap some pics. of the system parts that you can see, but I'm sure there are several components you can not see.
Koz
Thanks. I do a fair bit of pulling a utility trailer (without sway controls) and would like to investigate further. The more pics and info the better to see if this is workable.
Parts
Kmvreter said:
Any update?
Sorry for the delay. Promised parts list.
1) Tank assy
2) Tank assy Bracket
3) Tube #1
4) Tube #2
5) Tube #3
6) Compressor
7) Compressor brkt
8) Compressor Cover
9) Evaporator
10) Filter
11) Hose #1
12) Hose #2
13) Hose #3
14) Sensor link Right
15) Height sensor Right
16) Sendor link Left
17) Height sensor Left
Then you still need the electrical parts like the switch, harness, levelling wiring, gauge indicator, ECU, not the mention the compressor power, etc.
:bash: :eek:
