How did you tell which gear the transmission was at, given it's a auto tran? I suppose you put your auto shift lever at "4" ("D" would be overdrive ON and you said it wasnt appropriate for towing this sz trailer). Then the auto tran did its work behind the scene as you drive up the hill ... it probably downshifted to "3" when you climbed. But how could one tell which gear the auto tran is at other than the gear you shift to initially ? I dont suppose you use the auto tran as a manual tran sometimes and shifted on the fly? thanks.
THE V8 4RUNNER
Many on here lamented the idea of using the short wheelbase (110") 4Runner for towing a travel trailer. But let me tell you, it does very well. That 4.7 L V8 has an incredibly flat torque curve, and hits the 330 foot lbs. very early. Some of the grades were steep & long on this road. The trip has over a 6,000 foot elevation rise, and I ran it about 50 MPH up these hills, and about 60 MPH otherwise. Pulling steep hills it liked 3rd gear the best, and I think only twice went down briefly to 2nd gear. Didn
