10-30-2003, 11:03 PM
#1
Junior Member
Junior Member
Homelink Garage Door Opener
Anybody knows if I can get the Homelink Garage Door Opener option as a kit for my 2004 Sport Edition from a Toyota dealer.
Is it a plug in option or do I have to any wiring???
Thanks,
Bernie
10-30-2003, 11:14 PM
#2
Super Moderator
Super Moderator
I've not seen it as a kit, but have heard that the prewiring is already there. You could call Todd at Toyota of Richardson to see if there is a part for it.
If not, there are also auto-dimming mirrors with HomeLink built in -- go to the Mito web site at http://www.mitocorp.com/homelink_mirrors.htm for more information.
The site made it look like it would be fairly easy to install the mirror.
__________________
2003 SR5 V6 4WD Titanium with cladding
11-03-2003, 12:03 AM
#3
Member
Member
According to the 2004 4Runner brochure, Homelink is optional on the SR5 and Sport, and standard on the Limited.
However, if your Toyota distributor doesn't order vehicles from Japan with this feature included, you won't be able to get it unless you special order a vehicle from Japan with the feature on it -- or have your dealer seach the country for a vehicle from another distributor that might have it.
__________________
2007 Driftwood Pearl Limited V6 2WD
with Nav, Side Curtain Airbags, Running Lights
11-18-2003, 09:37 PM
#4
Junior Member
Junior Member
I finally get my Homelink unit.
Today I went to my dealer and after searching the Toyota DATABASE I was able to find the Homelink unit for my 04' Sport
I was not able to located it before because I was looking for a module, and it is not that. The Homelink system comes with the upper console, so I ordered the unit, retail was $126.00 and I end up paying only $75.00 because the dealer had one in stock that was ordered by mistake. The installation was a snap. It took me less than 30 minutes to have it up and running.
__________________
Bernie
San Juan, Puerto Rico
2004 Titanium Sport Edition,
V8, 4x4, 20% tint in front doors,
TRD Air Filter. Black Seat Covers, Sylvania Silver Stars, Home Link, Toyota all weather mats,Rear Spoiler.
11-18-2003, 09:49 PM
#5
Senior Member
Senior Member
I've been looking into doing this as well! Do you happen to have any part numbers or pictures of the install? Thanks!
__________________
2003 4Runner SR5 V6 4x2 - Pacific Blue Metallic/Taupe Leather
11-18-2003, 10:17 PM
#6
Junior Member
Junior Member
Part Number
The part number is 63670-0W030-B0, PLATE ASSY, MAP LAMP. The only difference from the stock unit is that It has the PC board and the three buttons for the HomeLink.
__________________
Bernie
11-18-2003, 10:18 PM
#7
Junior Member
Junior Member
Part Number
The part number is 63670-0W030-B0, PLATE ASSY, MAP LAMP. The only difference from the stock unit is that It has the PC board and the three buttons for the HomeLink. Hera are two Photos
__________________
Bernie
11-19-2003, 11:09 AM
#8
Member
Member
Consider a Homelink autodim
When we were shopping for a '03 Sport Edition, I wanted both an autodimming mirror with compass display and Homelink. The dealer couldn't locate either for me, despite what it says in Toyota's brochures.
I solved both problems by purchasing a Gentex autodim mirror with compass display and Homelink built in. Cost me $210 shipped, which includes $15 to have the displays and LEDs changed from green to orange to match the instrument panels in the 4Runner. Hookup was a snap (same as putting in any autodim mirror for which there have been lots of threads posted on this forum).
Just another potential option you might want to consider. Let me know if you want the info on the seller on these units.
11-19-2003, 03:28 PM
#9
Junior Member
Junior Member
Yes, I would like the address.
__________________
Bernie
11-19-2003, 04:48 PM
#10
Member
Member
The name of the vendor is Bob Prim. His e-mail is [email protected]. I originally found him surfing through autodim mirrors auctions on eBay and e-mailing him if he sold the Homelink inputs. Everything was delivered as promised and in "as new" condition, though not in original manufacturer packaging.
Good luck! Let me know if you need any more info. By the way, the most helpful document I found for a really nice professional install is the Toyota instruction manual posted by Woody on this forum:
http://www.toyota-4runner.org/attach...s=&postid=7114
12-04-2003, 05:06 PM
#11
Member
Member
How can you be certain that the homelink will work with your garge door openers?
I inherited Genie (Home Depot brand) when I bought the house.
__________________
Now available a forum for those that have a passion for body weight training http://www.bodyweighttraining.org/
12-04-2003, 05:52 PM
#12
Junior Member
Junior Member
Check your 4Runner manual it saids that will work with standard home garage door openers either regular or rolling code one's.
__________________
Bernie
12-04-2003, 06:34 PM
#13
Member
Member
Don't hold me to this, but I think that as long as your garage door opener was made after 1982, it should work with Homelink. Looking at Homelink's webpage, it should be able to be programmed to work almost any RF-compliant device in the 288-418 MHz frequency range. The key to programming is having a handheld remote for your garage door opener to hold up to the unit.
In any case, I wouldn't be worried with a common brand like Genie.
01-19-2004, 02:45 PM
#14
Senior Member
Senior Member
update
Quote:
Bernie The part number is 63670-0W030-B0, PLATE ASSY, MAP LAMP. The only difference from the stock unit is that It has the PC board and the three buttons for the HomeLink.
Just an update, I ordered this part but when it came in it did not have my sunroof button on it. The part number for this if you have a sunroof is: 63670-0W040. The only difference is one of the 3's is a 4.
Can't wait to put it on this weekend.
01-20-2004, 03:12 PM
#15
Member
Member
Homelink
Toybox, I have been looking for such a unit desperately!. Where did you order yours?. How much it is costing?. Is it easy to install (ourself) or needs to be done by dealer?.
I too have sun/moon roof in my Sport V8.
Appreciate your response.
Thanks.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
