Thai
Elite Member
Hey all,
I know that the FJ is not out yet but these two vehicles will be neck-and-neck with each other. Similarly priced. Similar customer base. Note: I am not considering the Xterra because it clearly falls behind these two vehicles in off-roading.
I testdrove a Hummer H3 this past weekend with my brother and his family. Conclusion: quite impressive.
- For top-of-the-line, it costs around $36-39K, including leather, 33" All-terrain tires, 4:1 transfer case, rear locker, NAVI, etc..
- Interior is pretty nice. Quality is probably not as nice as 4runner, but very nice for a GM car. Materials fit tightly and are of high-quality (for GM).
- Seats were comfortable. Getting into and out of the rear door is a bit tough, but decent. It is certainly better than my brother's LR Discovery SII.
- The ride was excellent. I could not believe it. Smooth, comfortable, even when driven off-road (mild-mod terrain).
- Wind noise was well-controlled (slightly behind 4runner). Road noise was non-existent, even with the aggressive off-road tires!
- 4-LO was impressive...tremendous crawl ratio (56:1 with automatics; 68:1 with manual). Throttle changes when switched to 4-LO...excellent for off-road crawling.
- Underbody is not totally tucked in. Similar skidplates as 4runner. This is surprising because the H2's underbody is relatively clean.
- Rear leaf springs...and it's mounted BELOW the axle. I don't get this. I wish that Hummer would have fixed this. They should have used coil springs, especially in a truck that only has a payload of 1150 lbs (thus, the heavy duty carrying capacity of leaf springs are not needed). I guess this is cost-cutting because this is carried over from the Colorado truck.
- Engine was weak. This rig needs a stronger engine. Period. Passing on the highway needs planning ahead of time. Acceleration is barely adequate. However, this is less of an issue off-road due to the crawl ratio.
- Windows are too small and rear view is bad. This truck needs a rearview camera or sonar.
- Turning radius is good (for a Hummer).
- Monsoon radio has a lot of bass...strange that this system only has 200 watts...it sounded stronger. However, the mids and highs were weak. So, if you're into bass, this system is perfect...if you're more into music details, then this system will disappoint.
- Rear cargo is kinda small and up high. The door itself opens/closes smoothly.
That's all i can think of right now. I can't wait to testdrive the FJ.
