Mafster
After having my new Pioneer hu installed, my radio reception went down the tubes. I learned from this forum about our diversity antennas that utilize 2 antennas in the rear of our 4th Gens--with 2 different size male antenna jacks up front to the factory radio.
Naturally, the new hu had only one input for an antenna (the larger of the two leads), so my installer connected it and power to the antenna. The result: poor reception.
I tried a booster, which did no good. Then on a whim I read about somebody using a Y antenna connector to channel both antennas into one male input for the aftermarket HU. Consequently, I ordered one and a upsizing adapter for the small antenna jack, and plugged them all in.
To be honest, I wasn't expecting much difference, but there was at least a 50% increase in reception! Still not as great as the stock unit (which is made by Eclipse), because there was no internal diversity switching, but a huge increase in reception (1-2 bars on my radio's display reception meter).
Cost is about $30 for the Y and the adapter.
For those of you who have aftermarket HU, I'd recommend trying this fix. Unless of course, you've found a better trick!
