Cleaning Your Car
Thai
Elite Member
Cleaning your car
Cleaning your car
by Paul Williams
Here are some suggestions that will make your car sparkle.
My standard kit includes car wash (shampoo), cellulose sponge, chamois, polish, wax, terry towels and tire dressing. Oh, and bucket.
Here's how to make a nice job of it.
First of all, when using polishes and waxes, do it in the shade, while the surfaces of the car are cool. This is very important.
Now, squirt some car wash in your bucket, and add water until it's about half-full. Then, throw in your sponge. I prefer a car wash that doesn't include wax, like Mothers California Gold car wash, Zymol auto wash, or Armor All car wash. These are all good. It's just soap, but it doesn't leave a film. These washes start at $9.99 (all prices from Canadian Tire Corporation).
If you want to get more aggressive, and remove all the old wax and polish, try Ivory dish detergent with Dawn. It won't hurt your paint, and it's designed to remove grease, right?
Now, hose down your car. You don't have to blast the dirt off, just get the car wet.
Start washing at the top of your car, and work your way down. Use lots of soapy water and gently sponge the roof. Then work your way around the car.
Don't go crazy, but don't work so slowly that the car dries. If this happens, wash off the soap as you go. Otherwise, hose the car with a gentle but steady stream when you're done. Again, start at the top, so it all flows down.
Now open the doors and use your sponge to clean the ends of the doors, the doorjambs and sills. Dribble water from the hose so it doesn't splash too much, and wash everything off.
Now dry the car. Lots of people use a leather chamois (pronounced "shammy") for this task. Pittards makes a nice one that stays soft after it dries out (starting at $19.99 at Canadian Tire). You can also use a Simoniz drying cloth ($14.99) or one of several artificial chamois. These products last for several years.
Start with the roof. Lay the chamois flat, hold the two leading corners, and pull it over the panel. Squeeze out the water, and repeat. You can do the whole car like this -- lights, windows, and all painted panels.
Remember, though, don't clean with a chamois -- it's for removing water.
Next up, the windows. Do them inside and out. EagleOne 2000 clear works well ($5.99), and Stoner invisible glass is nice, but has to be ordered online at stonersolutions.com. Paper towels are fine for this job.
I leave the wheels until last. Use what's left of your car wash if you want, but certainly use a different sponge. This is because there's typically grit on your wheels, and you don't want that getting into your washing sponge. If you've got alloys, make sure you wash all the brake dust off. Now hose down the wheels using a gentle stream, and dry them, too.
By this point your car will be looking good. To complete the job you can go a couple of ways. Either polish and wax, or use an acrylic finish. You'll get excellent results with both.
Remember, polishes and waxes are not the same product. Wax goes on top of polish. Wax by itself will protect and preserve a dull finish. No good!
Meguires makes fine products, favoured by many exotic and classic car owners. Their Number 2 or 7 liquid polishes ($9.99) and Number 3 or 26 liquid waxes ($11.99) require very little elbow grease and give great results. Or go for Mothers sealer/glaze ($9.99) followed by their Original liquid carnauba wax ($8.49).
It's very important how you apply and remove the polish and wax. The absolute best material is soft terry-towel, same as your bathroom towels. In fact, old hand towels are ideal. If you buy new ones, just run them through the wash-and-dry a couple of times to soften them. Use two, one for the polish and one to buff.
Apply a thin layer of polish to the roof of the car. Allow it to dry, then buff. Do the rest of the car section-by-section. Keep polish off the glass and unpainted trim, but anything painted is fine. You can polish your alloy wheels, no problem.
Now the wax. It goes on top of the polish to protect the shine. You'll find modern polishes and waxes require very little effort to apply and remove, and you'll get a terrific shine.
Alternatively, an excellent acrylic finish, and Canadian-made, by the way, is Crystal-Glo Acrylic Car Polish. Too bad these guys make it so hard to find. Try specialty automotive shops. If all else fails, order it from crystalglo.com. You can skip the wax with this product, which starts at $14.99.
Finally, the tires. The familiar foamy products are being replaced with aerosols or sprays. EagleOne is good at $9.99; Stoner tire shine is terrific, but it doesn't last long. Meguires Endurance tire gel is pricey at $14.99, but lasts. The foams work well, but tend to brown your tires after a while. This year, sponge tire swipes are available, and look useful.
One more thing. Just before you stand back and admire your work, move the car forward a half-meter, and look at those tires again. A missed spot on each tire will become exposed by moving the car, so get rid of those.
Now, enjoy your car in the complete certainty that you've single-handedly changed local weather patterns. You should be able to see rainclouds in a couple of hours.
Super clean!
I wash my truck almost the same as you except for this:
I start with the tires. I use Spray Nine and a soft scrub bush on the tires to get the heavy road scum off. I also do this to my chromed steel wheels (not recommended on aluminum since it sratches the clear coat). This gets my white raised outlined letters very white. After washing the whole truck I go over the tires and wheels with the sponge. Results are excellent. This process takes off everything including tire dressings.
DO NOT USE A SPONGE! The dirt has no where to go and you are actually HURTING your finish. The dirt gets trapped between your sponge and your clear-coat, and that is what causes swirl marks to form over a period of time. ALWAYS use a good deep pile wash mit. I use ones that have that scrubbing mesh stuff on the back which helps to get off bugs and other road junk, but wont scratch the paint. The deep pile of the lambs wool (or synthetic material) draws the dirt into the mit, away from the surface of the car, therefore preventing fine scratches from ever forming. FYI-The wash mits are cheap, so do yourself a favor and buy 1!
Also, a SYNTHETIC POLYMER wax (ie-Mequires NXT wax) will help seal the paint after the DAWN wash-down, and wont evaporate like regular wax when it gets hot (the evaporation temperature is MUCH MUCH higher with synthetics) It will last much longer.
Shaun
I JUST GOT MY 2005 4RUNNER LIMITED.
I USED MGUIARS PRODUCTS.
TO WASH I USE GOLD GLASS SHAMPOO & CONDITIONER
FOR MY DASH DASH TRIM FOAM
FOR MY LEATHER I USE RICH LEATHER FOAM CLEANER/CONDITIONER.
FOR MY RIMS I USE HOT RIMS
TIRES HOT SHINE TIRE SPIRE
I USE DETAILING CLOTH CALL ULTIMATE WIPE
www.meguiars.com
I am a member of meguiars club ther products are the best i ever used.
Your article shows a Canadian bias! :)
Stoner's is available at Wal-Mart.
I agree that a sponge is a bad idea.
Dont Use Toyotas Products?
Am i the only one that uses Toyotas wax and other car care products. I will not use anything besides the wax. I use it on my Land Cruiser and it makes that old thing shine like no other. I used it for the first time on my 4R last weekend (Monthly Waxing) and i really like the way it applies and it is very east to remove by hand, it only took like an hour to do all by hand, no buffer. Which my Cruiser took like 2 or so. Is there a reason i dont know about that yall arent using Toyota's stuff?
http://get.yourfile.net/?nt6986
Excellent thread! I'll add a couple of suggestions.
First, I would recommend using 100% cotton wash mitts, or high quality lambswool mitts. I would also recommend the 2 bucket method for washing. One bucket with the suds, and one bucket of clean water to rinse the mitt out after washing each panel. This will flush the dirt out of the mitt, and leave it in the rinse bucket, rather than in the mitt, or in the suds bucket.
For drying, I always go with a waffle weave towel after giving the vehicle a "flood rinse" that minimize the water left on the vehicle, as the flood rinse cause the water to sheet off, rather than bead up.
Anyhow, good washing techniques, and tools can really help minimze the number of spiderweb marks in the paint.
I found this neat place you drive-in hand the guy $6 and sit in your 4runner as it goes through this building and when it comes out it is clean :) Then every 6 months I go in and the dealer puts a sealer on my 4runner and I'm good to go. If I sound lazy it's because I am.
FYI - best thing to use for cleaning windows is Newspaper - instead of paper towels
Most anything is better than paper towels. I have heard it explained that paper towels use some sort of glue to bind the fibers and this glue is what causes the severe streaking seen with paper towels.
Clay Bar
Has anyone used a claybar before they wax to get all of the dirt off the clearcoat? If so, what brand do you use and how often do you do this?
Re: Clay Bar
Absolutely have used claybar. It really makes the paint slippery smooth. I don't do it everytime I wax though. I will probably do this once every year or two. I use Zaino's claybar but that was just because I was ordering other stuff. Any claybar should do. I saw a Mother's claybar at Pep Boys that I would have bought had I not already had one.
Re: Re: Clay Bar
How long did it take you to clay bar the entire car?
Re: Re: Re: Clay Bar
I guess about 30 to 45 minutes but I have unpainted cladding so I have a little less real estate to cover. It is quick and simple to do. Really you are just kinda wiping with the clay as opposed to rubbing which would take more effort.
Re: Re: Re: Re: Clay Bar
So you don't actually have to rub to hard with the clay bar...you wipe with it???
Re: Re: Re: Re: Re: Clay Bar
Yes it is basically wiping. You need to lubricate the surface first with slightly soapy water. (they actually make a lube spray for this but it is essentially slightly soapy water) and then wipe with slight pressure in one direction.
I can move along pretty quickly doing little sections at a time. You will actually fell it pulling some of the stuff off the car. You need just enough lube to feel it drag a little across the paint.
Re: Re: Re: Re: Re: Re: Clay Bar
Thanks for the tip, I will give it a shot this weekend.
I have to disagree on the use of shampoo for the car, they make liquid soap just for cars nowadays
Does anyone here use Simple Green?
That you guys know, is there a reason not to use simple green?
I used it on my truck to wash it and it is clean.
Granted I used more concentrate than that recommended by the label for washing cars, could using more concentrate than what is recommended eventually hurt the paint job? or strip the car wax?
wheel wells
Also wheel wells,( im kinda freaky about them being black) spray them with any aerosol tire dressing after a good hosing out and they will look like new.
