loner
I like to change my own oil, but I hate the idea of having to remove the skid plate to get to the oil filter on my V-8. Taking the skid off is easy, but putting it back on is an annoying task - and I'd just as soon make the job of changing my oil as quick and painless as possible.
A previous thread discussed how some people remove the oil filter from the top of the engine. This may work for some people, but not for everyone.
I looked into oil flter relocation kits, but abandoned that idea when when I figured out it would cost well over $150 to do it in a way that would not worry me about leaks or failure.
There has been some mention of modifying the skid plate to allow changing the oil filter without removing the skid plate. I looked at removing the filter by enlarging the gap between the skid plate and the frame on the driver's side in the wheel well - however, even with the skid plate out of the way, the sway bar and the radiator seem to prevent egress from that direction.
Recently while I had the skid plates off for another reason, I took a hard look at the bottom of the front skid plate. There are a couple of welded-in mesh screens whose purpose I don't truly understand. It looked like the screen on the driver's side seemed quite close to the oil filter and that may be a way to access it.
After a few minutes of figuring, I decided to take the plunge and experiment with modifying the skid plate. What follows is the modification I came up with. I think I achieved my purpose - to access the oil filter easily without removing the skid plate.
Some people will say that it is just as easy to pull off the skid plate at each oil change than to modify it. Yes, I acknowledge that. I am not suggesting that anyone else do this modification. I post it for informational purposes and because I know some of the mod-crazy people on this board might find it interesting.
