Avic-z1 Bypass Works!!!
ForRuner99 said:
let me know what you find out. i bought the z1 today! woohoo!
Hey guys,
Quick ?, why does crutchfield.com say that this unit won't fit in 4runners and sequoia? I have an '02 sequoia with JBL 6 disc changer...I'm concerned that it won't fit now...
CONFIRMED IT WORKS!!!!
I just tried the light trick, everything is unlocked now. I've been driving around watching King Kong...freakin' sweet!!!:D
edrock200 said:
Hey guys,
Don't worry about what Crutchfield says, if your opening is the same as the 4Runner, the AVIC-Z1 will fit, although you may need a Sosche DBL DIN Kit.
UPDATE: It doesn't matter if Parking Brake Wire is grounded or not, will work either way.
No need to pulse light 3x, just ONE pulse at startup is all that is needed.
And you don't even need to turn light fully on, just ONE simple parking light pulse is all that is needed.
I just CONFIRMED this.
Simple huh? Now go watch some DVD's in the car...:D
some good info from another forum:
green wire grounded (no connection to e-brake)
:start car and at "starting pioneer navigation screen" flicker your lights
:you have to hit "okay" to confirm connection is legal
:you also have to hit "okay" to confirm the e-brake isn't properly connected
:the dvd will then play regardless of the position of the e-brake
:you can switch in between navi, dvd, am/fm, and library
green wire properly connected to e-brake
:e-brake must be off
:the dvd will not play if e-brake is engaged and then released (must restart car and redo the whole process in order to get dvd w/o e-brake on)
note: when i say "flicker", it means the first initial screen will show a message at the very top stating the pioneer navigation is initializing and at that very moment you turn your lights on and off. the good thing with this is they can even be your parking lights so it's not as obvious that you're screwing around. if you do it at that very moment (since this screen is on for only a second or so), you only need to flicker your lights once. if you miss that screen i would just recommend restarting from the beginning, but i also had luck flickering my lights about 5 more times during the loadup screen following the initialization screen when i intentionally missed the first queue.
to me, the best way to do it is the grounded way, because then it doesn't matter how you start the car or if you have to use your e-brake for some reason, but there is an extra "okay" screen you have to touch because it knows that it's not connected properly
this is pretty much directed toward gaspar, but i'm sure it's informative to anyone else interested in the Z1.
I have an 06 t4r with the JBL system. I just came back from the shop right now and was gonna get the z1 installed but they said they didn't have a kit for my car yet. do you know if sosche makes a kit for my car with the JBL system?
unfortunately i have the JBL system with the in dash 6 disc changer. i guess i'll have to see if i can find a shop to custom it for an affordable price.
do you think it would work if i just purchased another trim piece. One that is for a 4runner without the JBL system.
Yes, you could do that but it's cost prohibitive. Both pieces that you need (the silver panel piece and computer display unit) cost about $1100 total.
ohh i didn't know it would cost THAT much. well i just talked to the shop and they said they would custom it for an extra 80 bucks so i told him just do it. i'm gonna bring my car in tomorrow and hopefully all will go well. I will update you guys after maybe with some pics also.
80??? Are you joking... all they have to do is make a trim panel out of ABS plastic which should take about 20 minutes tops. Thats a rip, seriously. I work at a shop in NC and 80 for that kind of trim ring? I would charge 30 tops.
