Rough Idle at start
palaoan
I've been trying to troubleshoot this problem with my 97 2WD, any help would be great.
It idles rough when starts, and after a minute it's smooth and normal. I've done the following but still have not alleviated the problem:
changed plugs and wires
changed 02 sensor (twice)
added fuel injector cleaner
changed gas stations
cleaned air filter (K&N)
replaced the throttle sensor (1 year ago)
The check engine light does not come on and it only happens after cold start. Lately I've noticed it happening after I leave the truck off for less than an hour.
Should I clean MAF or take it in for service and professional help?
No none replied but I found out the problem. I thought I'd share it just in case anyone runs into the same thing.
Rough idle was due to coolant in the head, which ended up having stress cracks. I bought a new head for about $500, not including the machine shop cost to resurface, seal, etc. That totalled about a grand.
I thought it was the MAF or the 02 sensor initially, but it turned out to be something bigger and more expensive.
I hope this helps anyone in the same situation.
It's a 97 4cyl. 2.7 3RZFE 130K miles.
When the head came back from the machine shop, I saw the cracks.
Coolant leaked in the head, which was the cause of the rough idle when it started.
I was just pointing out that if the sensors are replaced, 02 and MAF, and the problem persists, it could be a sign of a bigger problem like it was for me.
