Falls said:
Thank's for the info, but I really don't know much about stereos/amp's and such. I also would like to remove my 2 rear view mirrors and put the speakers in the from the 10 speaker system.
Keep your stock headunit, esp. if it has disc changer in it. If you have just a one-disc headunit, then it may be worthwhile to change it out to an aftermarket unit for ease of installation and, maybe (to a very slight degree), better sound.
I would not play the look-at-my-10 billion-speakers game. IMO, i would just get a real nice front component speakers (tweeter + woofer). Infinity Reference speakers are nice and cheap (less than $200). Good quality. If you want to go further high-end, then i would seriously consider Polk Audio SR6500s (about $750). There are many other choices...most are good. However, the two choices that i have mentioned are my favorites.
Next, i would either keep the stock rear speakers or just change it out to something cheap. These rear speakers are mostly for "rear fill". The main sound stage for both front and rear passengers will be the front component speakers.
Then i would get a real nice amplifier. If you went with Infinity Reference speakers (or any speaker within that price range), then you can get away with a small amplifier. I would NOT get any cheapo brand (Jensen, etc)...it does matter! I would get a 4-channel amp from a reputable brand (MTX, Alpine, JL audio, Kicker, etc.). For the Polk Audio SR's, you would need a high quality powerful amplifier (my fav amp is JL Audio 300/4).
I would mount the amp to the backside of the rear seat. Pick the backseat side that you use the least...probably driver's side.
Finally, to add some nice clean bass, i would consider Infinity Basslink. Why? Basslink is an all-in-one unit (amplifier + subwoofer in small package). You can then bolt/strap it to the cargo area with minimal loss of space. This way, you have good bass from a small package and it can be unbolted if you need more cargo room. You can ask someone to make a box for you, but then you will need a separate amplifier just for the subwoofer. Again, this will cost $$$$ and cargo space.
There...you are finished. I would not bother with adding any other speakers. This is the classic setup (6 speakers + 1 sub) will provide great sound without doing too much work on your 4runner. Keep it simple...minimal surgery to your 4runner.
Good luck.
