Weight-distributing hitch for 2003-4
surfman
The owner's manual for my 2003 SR5 V8 4WD says that it can pull a trailer weighing up to 7,000 lbs (p. 262). This is in agreement with the present capabilities of the 2004 models (http://www.toyota.com/vehicles/2004/4runner/specs.html).
The manual also states to "use only weight carrying hitch hardware ... with the factory installed hitch" (p. 264). However, this does not make sense to me. A trailer weighing 4,000-7,000 lbs would almost surely need a weight distributing hitch, right?
On my 4Runner, the hitch receiver is a small block-shaped unit bolted to the rear frame cross member. Therefore, I suspect that it is not designed to handle 7,000 lbs. and that I would need to replace it with a heftier WDH to safely pull such heavy trailers. Do you agree?
Then a couple days ago, I dropped by the dealer to look at the current 2004 4Runners. They all appear to be equipped with a much heftier hitch receiver, one that shows a 7,300 lb. sticker. This hitch is bolted to the two side frame rails instead of simply to the rear frame member, like mine. I asked the Parts Department about this heftier hitch, and they replied that it is only available as factory installed option. :(
I don't plan to pull a 7,000 trailer, but I do want to pull one weighing at least 5,000 lb. with a WDH, so I want the hitch to be as strong as possible. I have looked all over the web for a equivalent hitch to the 7,300 lb. Toyota one, but I could not find anything. Is it just that the '03-04 4Runner is so new that third party hitch manufacturers have not gotten around to making one as hefty?
Thanks for the help.
Thanks for the pointer, Woody.
Here is what I found at the Hidden Hitch website.
Part # 70411, which is a round tube style Class III Trailer Hitch, is made for the 2003-2004 4Runner. It has a 5,000 lb. rating for use with a weight carrying hitch and a 7,500 lb. rating for use with a weight distributing hitch. This appears to be just what I am looking for!
The pdf instruction sheet shows how to install the hitch. I like the way it attaches to the frame side rails and to the rear cross member, using a total of 8 bolts. These instructions seem very clear, although I would like to see what the final installation looks like. Does anyone have this hitch or another like it? Can you comment on its build quality?
etrailer.com sells this hitch for $114.62. Is this a good place to buy one?
For more information about towing a trailer, see the various pdf files on the Hidden Hitch website, as well as the NHTSA towing guide.
I had a Hidden Hitch on my 2nd gen truck and I really liked it.
I tow a three passenger Jet Jki so I only have to worry about 1200-1500 lbs so I didn't get the Hidden Hitch but $114 is a real good price. Check this site out and see what they have. Hitch-Web . They are good people.
I find that hard to believe... yes all 4Runners have a hitch installed at the factory but what if someone gets into an accident and it gets damaged? All of a sudden they need to use a 3rd party hitch? Seems like someone didnt want to go through the trouble to look up the part number for you.
Trailer hitches
He's actually right and not along. I've been battling with 2 dealerships and Toyota Customer Service (or lack of) trying to find out about a class IV hitch that they mention is required to go up to 7200 on their own website.
I finally gave up and am searching for 3rd party hitches as well. Besides hidden hitch, any other good ones?
Cheers!
John.
This is very familiar territory. Repeated requests for clarity around the class 3 or class 4 hitch classification for the 03 4Runner have not provided answers. The most recent response suggested a class 3 hitch BECOMES a class 4 hitch when weight distribution is added. I was about to go this route, assuming it meant I had the 7200 lbs of pulling power the manual suggests, until I read this page. Toyota really should be able to do better than this. Has anyone simply had the 03 class 3 hitch removed and replaced by the 04 class 4 hitch....by a dealer? Thanks,
don
