Yet another Cornfed install
MW 4Runner
I know I'm about the 1,000th person to post this, but I always enjoy reading what new lift owners have to say. I installed the Cornfed 3"/2" lift today on my '05 Sport. Got it from Burtman (great guy and great service... just like everyone always says), it took a little over 2 weeks to arrive, but that was b/c thanksgiving fell right in the middle of that. On to the details...
Pic of the kit
I installed it at a friend's shop. He has the whole set up, lift, air tools, etc... This made the whole deal MUCH easier and FASTER. I've got some serious respect for you guys that installed in your drive way with jack stands and hand tools. Did the rear first, and had it done in probably 30 min. Had a little trouble getting the driver side coil back in after doing the passenger side first. With the spacer on top of the coil it was tough to get the bottom of the coil to seat, so we broke out the coil compressor and it was in no problem. I think this was due to dropping the whole axle at once instead of doing one side at a time.
Pic of the rear installed
The front is a little tougher. I definitely recommend disconnecting the upper A-arm balljoint on the front suspension. This isn't in the Cornfed instructions but after reading write ups on here and other sites for the past 6 months it was a no brainer. The coil/shock assembly just drops right out and makes spring compression for those of us with xreas alot easier. The front took a little over an hour. I can't imagine trying to do all that work bent over on the ground working with jack stands (again serious respect for those that have done the install that way). The whole install took 2 1/2 hrs, this can definitely be done in under 2 hours after doing it once.
Pic of the front installed
I was concerned after reading all about how the ride stiffens up on the rear, but I seriously cant tell a difference. It rides more like a truck now to me, but I think thats just from the higher ride height. I went over speed bumps, rough roads, interstate and I can't tell a difference. I really didnt know what to expect it to look like in person after the install. To me it looks "correct" now, sits up like I think a 4Runner should sit. None of the pictures on the internet really do it justice. I'm getting new tires Monday and then doing an alignment. Here are a couple quick pics of before and after. I'll post more after the tires are installed and I finally get a chance to clean it up.
Before
After
The ground wasn't perfectly level right there but I'll get better pics in a couple days.
Falls said:
Nice , what size / type rims & tires are you getting.
Lift looks great
Thanks!!
Stock Rims & 265/70-17 tires
In person the stock size tires dont look bad at all to me. After I washed it yesterday it looks even better with the lift, I dont know why? :D I'll take more pics with actual measurement after I get the tires installed today. Ive got all the measurements from various points from before with stock size tires, after lift with stock size tires and I'll have after lift with upsized tires too. I'll post all this later.
so whats that kit run you cost wise? I really like that setup. I am kinda new to this whole moding thing and to this site, but I do want a modest lift and that seem like a good way to go.
Kudos for doing it yourself.
Burtman Industries
The only other cost I can think of if you installed it yourself would be buying some new cotter pins.
FYI... My local offroad shop wanted $250 to install the lift.
MW 4RUNNER
I have looked into getting a lift for my 2004 4runner sport 4x4, I was under the impression that with the XREAR i was not able to get a lift with out removing the XREAR system.
Can you tell me if you had any problems with the XREAR system, is it still working like normal .....
Thank youin advance.
By the way, your 4runner looks great ... :bigok:
MW 4Runner said:
Burtman Industries
This kit will work 100% with the XREAS system, no worries, just follow the install instructions to the T. You don't need new shocks, it works 100% with your stock suspension. :)
Thank you jasonb,
where will you recomend I buy the parts from and what exacly did you get for your front/rear lift ....
:bigok:
Just got the tires installed. I took advantage of the "Toyota ExtraMile Extended Life Tire Program" which is a deal where you get free tires for up to 100k miles as long as the dealer rotates them every 5k miles. As far as I know this program is only in the "Gulf States" region. The only negative is the limited list of tires you can pick from, but for free tires I gave it a try. I picked the Goodyear Wrangler RT/S in a 265/70-17 size. Would definitely not have been my first pick if not for this tire deal, but it was the most aggressive all-terrain that was on the list.
On to the pics!!!
Here is a good BEFORE pic for reference
Here is AFTER WITH STOCK 265/65-17 TIRES
And here is AFTER WITH 265/70-17 TIRES
I will post all my measurements tonight after I get the final ones with the new tires installed.
It look very nice MW 4RUNNER, i can wait to get this set up for my runner, I'm hopping I can get this done with in the first 2 months of 2007 .....
Looks even better :)
Kits take aprox 10-15 business days to make normally, but those that order on or before 12/12/06 you will have it by Christmas.
Those wanting something different than the 3/2 kit shown on the website, just call or email, will be here over weekend as well.
Thanks Everyone!!! I'm very happy with it.
Here are some measurements...
Front fender (center of wheel)
Before lift - 32 3/4"
After lift (w/ stock tires) - 35 1/2"
After lift (w/ 265/70-17 tires) - 36 1/4"
Rear fender (center of wheel)
Before lift - 35 3/4"
After lift (w/ stock tires) - 37 3/4"
After lift (w/ 265/70-17 tires) - 38 1/2"
Running Board (Front)
Before lift - 11 1/2"
After lift (w/ stock tires) - 14 1/4"
After lift (w/ 265/70-17 tires) - 15"
Running Board (Rear)
Before lift - 12 3/4"
After lift (w/ stock tires) - 14 3/4"
After lift (w/ 265/70-17 tires) - 15 1/2"
CORNFED!!!
Looks AWESOME! I'm so stoked about getting my 4runner lifted!
I just got my Cornfed 3/2 today. And SHUT UP, Burtman, it didn't take as long to get it as you said it would. Give yerself some credit! I was afraid I wouldn't get it before Xmas, but I got it! THANKS!!!
Now just need to find an installer in the DFW metro (Texas).
Any suggestions???
Thanks!!! I really love it. Though I have found myself thinking of 285's and a 1" body lift... It never ends :D
Here is a link to ANOTHER THREAD showing an installer in Dallas. I don't know anything about them, I just remembered that being posted a while back.
ObeseFieldMouse said:
how about some ground to skid plate measurements after the lift...id like to compare that to stock also
It's right at 12"... I don't have any idea what before was (I'm guessing around 9"). This was just a real quick measurement out in my driveway just now.
Here are a couple updated pics with some new stuff installed.
Westin Safari Bar with Hella 500 driving lights
PIAA L105 Extreme Position Lamps (wired up for back up lights) and a Receiver Hitch Shackle
The Hella's light up the road pretty good, though I think I may switch out the bulbs for some PIAA Xtreme White Plus H3 (55-110 watt) bulbs just to see if they can get even brighter. I'm waiting for the stock looking Tacoma Fog Light switch to arrive right now, so I just used the Hella switch that came with the lights for now. When the FREE Westin lights arrive I might mount them to the Loadwarrior (though I do enjoy parking in the garage so I don't know). I just finished wiring up the rear lights and havent seen how they look in the dark yet. As small as they are I doubt they put off too much light, funny how website pics show them to look much bigger than they really are.
Here are a couple more pics of some other little things I've done lately. I had a little fun with some paint pens here...
And here..
And of course I had to post a pic of my truck after I tore through some mud on my jobsite...
Funny how before I found this site I hadn't done anything to my truck... I love this place!!!
