Day Time Running Lights
Yaouch
I have a 2000 Toyota SR5, just purchase it and I knotice that it has day time running lights. I first thought if I just pull out the fuse and it should turn off. So I pulled out the fuse that has "DRL" writen on to fine that the light was still on..... Dose anyone know how to turn off the day time running lights for good. I dont need it on all day, and sometimes when I pull up my house at night and want to sneak in so I turn off all my lights.. In this case the DRL is on, I cant do that......
Not quite sure how to turn them off maybe check relays. I do have a suggestion on turning off your lights though. Turn off the engine off and pull the handbrake, then start the truck and let it down until it just about goes off, so the pads aren't touching. Now drive and your lights will stay off.
On the 2000 models, pull out the BLACK with YELLOW STRIPE wire from the connector plug that goes in the DRL relay. Its the grey box with a large plug and 13 wires above the gas pedal. Use electrical tape to secure the wire out of the way.
Is this a temporary option?
The reason why I ask is because I am planning on going on a trip where I do not want the DRL to be on for the week while I am camping.
I don't get it; DRLs are only on when your car is running, what difference does it make if you're camping for a week or just driving?
Plus, if your car is on, or just the ignition, and your E-brake is pulled, they're off anyway.
So once again, I don't get it.
Yes. Simply push the wire back into the main connector and plug it back in. The hard part is removing the wire without damaging the plug if you dont have the proper tool, but it can be done.
I will be stargazing for the week.
There is nothing like fifty angry people who spent the last few hours trying to adapt their eyes to the dark, and then blinding them with lights. :bash:
Camp site and observing site are in two different places.
I just want to temporarily disable while I'm on this drip and engage it back when I get home. :cool:
dirtydeeds said:
This is a mod I've been wanting to do, just haven't gotten around to it. Here's a tech write up for it for a 2001, should be the same for a 2000:http://www.yotatech.com/showthread.php?t=75269
Okay to begin with, this write-up is for a 2001 4Runner. Even then I would not recommend using this paticular one.
There were 2 different designs in the DRL Module for 3rd Gens. 2000 4Runners and ealier models w/ DRLs, have a box in the engine compartment by the battery that can be unplugged to disable them.
In '01 & '02 4Runners, Toyota ditched this box that could be unplugged. For these year 4Runners, owners must snip a wire to disable the DRLs. However, even the write-up you mentioned in your post can cause problems. It will disable your DRLs, but will kill the DRL module. Therefore, if you ever wanted to have DRLs again, you'd have to fork over close to $300 for a new module.
Instead, owners with a '01 & '02 4Runner should follow this write-up:
Disable DRLs on a '01 & '02 4Runner
You don't have to install the switch like stated in the above write-up, but this write-up will show you which is the correct wire to cut without killing your DRL module at the same time.
I learned this lesson the hard way. (I killed my DRL module). But then again, I don't ever plan to run DRLs anyway, so it's no real loss.
Don't know of a write-up on how to disable DRLs on a '00, but simply put - find that box as described above and unplug it. That'll do the trick. No need to cut wires unless you just want too.
