Run'n'Gun
So I got my suspension lift in the mail on thursday from www.wheelersoffroad.com and put in on yesterday. I had my roommate help me with the install as I helped him put Koni Adjustable shocks,struts, and springs on his Saab Viggen last weekend pain in the ass those Euro cars. Total time for mine was about 4.5 hours for the install and wasn't too bad at all. I have an 03 limited with xreas which wasn't too hard to take out either, and to take it out properly so it didn't leak of get damaged. I would rate this project a 5 out of 10 for difficulty. You don't need any special tools, just basic metric box wrenches and sockets.
Lets start with step 1, removing the XREAS: First after your rig is on Jack stands, use 4 it makes this much easier. Locate the xreas hub on the frame rail and disconnect the bolt on the end of it.
<a href="http://photobucket.com" target="_blank"><img src="http://i22.photobucket.com/albums/b316/grahamhebson/IMGP0184.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
There is a check valve in the fittings that stop the oil from leaking.
Next disconnect the the brackets that hold the xreas lines to the frame, I sprayed a little pb blaster on the bolts to get them off, some were stuck in there pretty good with road grime.
<a href="http://photobucket.com" target="_blank"><img src="http://i22.photobucket.com/albums/b316/grahamhebson/IMGP0185.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Then disconnect the rear shock from it's mounts keeping the bottom stud to reuse on the new shocks. Do this on both sides first as it will make it easier to get the new ones in. Remove the xreas hub from the frame, you can pull the shock out with the lines still attached. Get the bottle jack out of the compartment on the left of the trunk as this little guy really helps out. After you remove the shocks put the bottle jack inbetween the bump stop and the axle housing and extend it so it will push the axle down and remove the stock springs. Here is a pic of the new springs and the stock one.
<a href="http://photobucket.com" target="_blank"><img src="http://i22.photobucket.com/albums/b316/grahamhebson/IMGP0186.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
and one of the rear fully removed.
<a href="http://photobucket.com" target="_blank"><img src="http://i22.photobucket.com/albums/b316/grahamhebson/IMGP0187.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Then put in the new spring using the bottle jack to give you clearance, no pry bar necessary.
<a href="http://photobucket.com" target="_blank"><img src="http://i22.photobucket.com/albums/b316/grahamhebson/IMGP0188.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
