pics of my ride 96 base
riceandpho
Elite Member
pics of my ride 96 base updated pics.
heres some pics of my ride,
http://smg.photobucket.com/albums/v310/riceandpho/car/
mods are pioneer 8600 deck, and the 6disc dvd changer,a/d/s/ al6 components in the front, focal access 130ca in the back, jl audio 12w3v2 in the trunk, jlaudio amps, 300/4 under driver seat, and 500/1 in the trunk, catz msx fog gold with 85 watt bulbs, changed from the 55,piaa extreme white plus all around, blue leds from superbrightleds, hids from www.retro-solutions.com, 55 watt digital kit and lifetime warranty for 250, also its a bixenon so i still have high beams, knight rider scanner light, so far it made 2 4runners pulled over lol, hella supertones, ccfl blue light are from retro-solutions.com, compustar 2way 3000 ft alarm, 5% tint all windows except, 55% on front two.400mm broadway mirror. oddyssey pc1700mjt battery, intake with a trueflow foam filter, filter was from jason burtman, mobil 1 oil, 0/1 guage big 3 upgrade. ngk wires, soon to put denso plugs.
HID review, the light output is amazing, what a difference from the piaa extreme white bulbs i had in there, there is no glare, but u cant really tell from the cam, but u can see there is no glare in person, also for 250 and lifetime warranty and great service, www.retro-solutions.com is good, i have the 55watt digital kit, also its a bixenon so u still have high beam working, its the one where the bulbs moves back, also there is still a good cutoff, u can tell in the pics, i took some pics while drivin so its not that sharp, but u can barely tell that i had my fogs on, some pic i have my fogs on, but the others are just hids, there are some pics of high and low beam and all lights on together. also that pick up truck u see infront in the driveway is my dads 06 tacoma double cab long bed, with the roll-n-lock. also the security system on both trucks were done at audiomoble of oakland, so if your in the bay area get your car hooked up there.
Give us time to reply.
You have alot of stero equipement in it, not bad. Is it two different colors yellow and or white/gray.
hey dude! looks pretty good, how did u get the blue lights? i wana change them out from the green or put some super white LEDs in.... did u replace all the bulbs?
yea its white i will upload new pics soon, as far as lights, i changed all of them, u have to take apart the cover panel where the vent is on the driver side, then take out 4 screws that holds the trim for the speed and tach, then u get that out, and then u see 4 bulbs that is 168, do not change the bulb to led for the gas, or it will light up all the time, its not that hard.
black, u ccan tell if its black or carbon fiber, the black is all flat, while carbon fiber u see some white lines with the black.
Lookin clean man, those HID's are badass.. I really want some.
You should get some some clear corners & clear signal lens, it'd look even cleaner.
u can get them for me for christmas lol, ill keep it as is right now, dont want to b bother by cops, after i got the 110 mph with the 4runner, i dont want the cops on me, get the hids from www.retro-solutions.com ,i have no glare, just came back from a road trip, dark road us50 highway to lake tahoe, and all the cars had to use there high beams, while im still on my lows and fogs, didnt have to touch my high beams at all, yes i have bixenon 55 watt kit 5000k . there is absolutly no glare. best thing i bought and has lifetime warranty foir 250 bucks.
hey i really want to swap out the bulbs to bright white! or a real light blue tent..... almost like is shows depth!
was replacing the dash and guadge bulbs hard?
how long did it take you?
Truck looks good.
Although I think the neons might be a bit bright for the inside. I like you hids and fog setup. I might be adding fog lights and hids myself now. Did your hids connect to the oem harness or to the battery? Did they have fuses to protect the electrical system? Where can I get that those terminal distribution that you've got on your battery terminals? I've never seen those before. I'll probably have to hit you up for some info later on to see how you routed the fog light wiring to the inside of the car.
hids i got from www.retro-solutions.com , 55watt bixenon 5000k, its plug and play, also it comes with a harness and fuse, with relay, it connects to ur oem plug, then the harness u put it to ur battery plus, also the batterry terminals is monstercable 300series slimline battery terminals, they strip if overtighten. fog lights i got is the catz msx gold fogs which display 93 degrees , instead of there drivin ones which is 40, u can find the fog 93 degress on ebay, some guy was selling it for 80 for the kit, other than that u wire it up to the battery plus, and plug in the relay, then route the switch wire to the inside and look for the parking light wire (oragne) and wire it up.
I love the look of your tail lights! Do you mind letting me know where did you purchased them? How do you find the overall quality of the lights?
I am thinking of adding those to my '97. :cool:
