HiVel-JR
Anyone running a 255/75R17 tire size, just curious to see how it works.... if it works at all?
I know about the 265/70R17 size, honestly I am being cheap and noticed that the 255/75R17 are cheaper... and bigger, not wider
I did the calculator on them.... I just wanted to know if anyone is running them. Thanks Have a good Thanksgiving...
Stock Tire - 265/65R17 Tire 1 - 255/75R17
Width: 10.43 in 265 mm Width: 10.03 in 255 mm
Rim Diameter: 17 in 431.8 mm Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7.5 - 9 in Rim Width Range: 6.5 - 8.5 in
Overall Diameter: 30.56 in 776.22 mm Overall Diameter: 32.05 in 814.07 mm
Sidewall Height: 6.78 in 172.21 mm Sidewall Height: 7.52 in 191.00 mm
Radius: 15.28 in 388.11 mm Radius: 16.02 in 406.90 mm
Circumference: 96.00 in 2438.4 mm Circumference: 100.6 in 2555.2 mm
Revs per Mile: 680.6 Revs per Mile: 648.9
Actual Speed: 60 mph 100 km/h Speedometer1: 57.2 mph 95.3 km/h
Speedometer Difference: - Speedometer Difference: 4.885% too slow
Diameter Difference: - Diameter Difference: 4.65%
