02-09-2008, 12:13 AM
#1
Member
Member
Fuel injector voltage
I need to check if the wiring is good to my fuel injectors, and I'd like to see if I'm getting voltage to the connector. Do the fuel injectors fire with 12v, or a lower voltage? I want to connect a lamp to the terminal and see if it flashes when the engine is running.
I'm also looking for a pinout on the connectors on the ECU if anyone has one. I also found that my engine ran a bit smoother with my spare ECU from an '88 than the original '87, are the differences in ECUs?
Plus, I know my problem is with fuel not reaching my cylinder. Is it possible that the valve could be stuck closed keeping air and fuel from entering?
__________________
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
02-10-2008, 11:23 AM
#2
Senior Member
Senior Member
I know nothing about your model year and Toyota has used many different types of injectors.
Most of the time the injectors see battery voltage from the ignition switch and the ground is provided by the ECU.
If I suspect a bad injector, then with the engine running I disconnect them one at a time with the engine running to isolate the bad one.
Some injectors types are low resistance ones ( 2 ohms) and some are high (14 ohms)
A back-probed 12volt test light will also work well. It should flicker like mad.
__________________
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
02-10-2008, 09:46 PM
#3
Member
Member
I know my injectors are good as they were just cleaned and tested. I'll try a test light and see if it lights.
__________________
02-12-2008, 04:59 AM
#4
Member
Member
I don't know if you are still having injector problems or not but I saw this thread on Yotatech and thought it might be of some help (although the guys final solution was a bit esoteric to say the least!).
http://www.yotatech.com/f115/cam-gear-chain-136493/
__________________
1985 4Runner
1997 FZJ80
2007 HDJ100 - DD
02-12-2008, 07:46 AM
#5
Member
Member
What I'm finding from other sources is that the 22RE uses simultaneous injection, where all four injectors actually fire at the same time. This should be a simple continuity test to see if the #1 injector is wired up with the other 3, and if not, I should be able to simply run new wires from one injector to the #1. I'll be looking at everything tomorrow, hopefully I can be up and running by tomorrow afternoon.
__________________
02-13-2008, 02:09 AM
#7
Member
Member
What's the difference then between the '87 ECU and the '88? I popped the '88 one in to see if I had a difference in performance, and the engine seems to fun better with it...
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
