Runs so Poorly
twelve02
Hello All,
I'm new to the thread but not new to owning my 4-Runner.
It's a 2000 Limited 4x4 with 114K miles on it. It runs horribly, has no power and gets horrible gas mileage. I've had the O2 sensor replaced twice and just recently had a major tune-up with plugs, wires, cap etc... My check-engine light comes on within a day of resetting it because of a constant lean condition. I have had it checked 3 times for this and nothing seems to be helping it. In traffic under constant stop and go the truck stalls frequently. Under acceleration the truck bogs and has virtually no power. Do I need a new catalytic converter? Can I use a different chip to get rid of the governor? Any ideas, thoughts or suggestions would be greatly appreciated.
Thanks.
You need to find out what code you have first. How did you put a cap and rotor on it? The 00 limiteds have a V6 which dont have distributors. What kind of plugs did you use? A ecu chip wont solve anything. How do you know if its a lean condition? If your code is a p0171 I agree you need to either clean or replace you MAF
