twfran said:I waited long enough that there is now a front hitch receiver available specifically for 4th gen 4Runners. HitchesOnline sells it. Fairly easy install. The hole spacing was a little short, so it had to be horsed around a bit to slip it onto the frame bolts. Also had to unclip the EPDM mud guards behind the bumper. Took about a half hour once I figured out what needed to be done.
Thanks for the warm welcome!
Been lurking for a while. Lots of good info here. Good people too.
twfran said:Several things over the years:
- Surf basket for coolers
- Winch
- Pull/tow hooks
- Bike rack
Thanks so much TW, i had started another thread right about these back may 17th, We go down to south bethany/fenwick island state park. This will definitely give us some more room getting over onto the beachtwfran said:It's from hitchesonline.com and their online search tool gets you to the part number for your model year.
That is a "skid plate" in the receiver. Really just an angled piece of steel plate. You can get them from hitchesonline and other places.
Both of the pieces are actually made by Curt Mfg.
Definitely a perfect fit. No drilling, just a little swearing...
twfran said:Here is a pic of the outside frame bolts (looking up from directly beneath the frame end). The front hitch receiver has a clearance hole for the lowest of these bolts...
twfran said:No problem. Those brackets are 1/4" steel plate.
