One Touch Up/Down on All Four Windows
Jeffrey_VB
After seeing the thread re: having the dealer set the key fob to unlock all four doors with the first push of the unlock button, I am wondering, can the dealer set the power window buttons on the driver's door to be one touch up/down on the other three doors?
I think that has to do with the type of switch thats installed - maybe if you (can) replace the other switches with one like that controls the drivers window it can be done.
I'm not an expert, but I'm pretty sure its not a "programming" issue.
I don't think it is possible because on the one touch you can roll it up normally or the one touch. Now what you have only rolls in up normally. There is no other one touch option so if you did get it to be programmed you could only roll it all the way down or all the way up.
