2003 Acura MDX
Thai
Elite Member
Hey all,
Here is the official word on the 2003 MDX. Does it apply to 2003 Honda Pilot?? I do NOT think so. Maybe the 2004 Pilot will have these upgrades.
No side curtain airbags, no HID lights, no change in wheel size, no full size spare, but other than that, pretty much everything else has come true, like 260HP (3.5L engine), VSA, enhanced Nav, etc.:
More Powerful V-6 Powertrain Delivers V-8-like Performance
Torrance, Calif. 09/18/2002 -- The 2003 Acura MDX luxury sport utility vehicle receives a number of performance improvements and additional features designed to enhance its position as the benchmark in the luxury SUV category. Engine modifications including a new free-flowing exhaust system, boost horsepower from 240 to 260. An all-new, more compact 5-speed automatic transmission is quieter, and provides even smoother shifts. Suspension and chassis refinements, the addition of Vehicle Stability Assist (VSA) and a drive-by-wire throttle system derived from the system on the NSX supercar combine for a smooth ride and ultra responsive handling. Inside, the available Acura Satellite-Linked Navigation System receives several important new features, including voice recognition and a rear view camera. A DVD Entertainment System is now available as a factory-installed option.
"The MDX continues to be the most sought after luxury SUV on the market and the changes we've made for 2003 make it even more desirable," said Dick Colliver, executive vice president, auto sales. "With performance better than most V-8s, retuned suspension and the addition of VSA, the MDX's power, handling and ride quality will be tough for any SUV to match."
The 2003 MDX's 3.5 liter, 24-valve, all-aluminum, VTEC V-6 engine benefits from a retooled exhaust system that includes two close-coupled primary catalytic converters, a secondary underfloor catalytic converter, and larger diameter exhaust pipes. These refinements increase exhaust flow by 40 percent and, when combined with new integrated cylinder heads and a shorter intake manifold port, boost horsepower from 240 to 260 and torque from 242 lb-ft to 250 lb-ft. Combined with new, orifice-type fuel injectors, the new exhaust system makes the MDX the first SUV to meet stringent ULEV-2 emissions standards. With estimated city/highway ratings of 17 mpg city/23 mpg highway, it delivers better combined fuel economy than any of its luxury competitors.
To handle the increased engine power, the 2003 MDX receives an all-new, compact 5-speed automatic transmission. This new 4-shaft gearbox is 60 millimeters shorter than the previous transmission and features increased torque capacity. A unique shaft center design not only reduces size, but also reduces gear noise, clutch drag and hydraulic friction.
The 2003 MDX also features a new drive-by-wire throttle system, evolved from the drive-by-wire system in the NSX supercar that has been custom tailored to meet the unique demands of a SUV. This innovative system eliminates the need for a mechanical connection between the accelerator pedal and the engine, and controls the throttle during transmission shifts for improved smoothness. It also allows for throttle control to be incorporated into the MDX's VSA logic and controls the vehicle's cruise control function.
The 2003 MDX's standard VTM-4 four-wheel drive system has been recalibrated to improve performance, especially on low friction surfaces. Torque distribution to the rear wheels has been increased by up to 30 percent, providing a significant improvement in the MDX's prowess in snow or other slippery road conditions.
In addition to ample power, the 2003 MDX delivers sport sedan-like handling and a smooth, compliant ride. The suspension has been retuned to deliver an even smoother ride while maintaining the vehicle's precise handling. To accomplish this, rear spring rates were increased while damping rates in both the front and the rear where reduced. New rear damper valves were adopted to enable more precise control of damping throughout the suspension movement. At the same time, dynamic torsional rigidity of the body was increased 35 percent by reinforcing the rear wheel house, tailgate and rear subframe.
Handling is further enhanced through the application of a new Vehicle Stability Assist system (VSA) that works in concert with the VTM-4 and drive-by-wire throttle systems to provide enhanced control during acceleration, braking and cornering. This 4-channel system orchestrates the throttle and each of the vehicle's four disc brakes to seamlessly integrate traction control, Anti-lock braking, and stability enhancement for increased driver control during acceleration, braking and cornering.
The MDX features 4-wheel disc brakes with 4-channel ABS, dual piston calipers in the front, standard 17-inch alloy wheels and specially designed P235/65R-17 all-season tires to provide stability and responsiveness. Front and rear stabilizer bars, a wide track and a low center of gravity give the MDX predictable cornering response and help maximize cornering capabilities.
The styling of the MDX strikes a balance between muscularity and elegance. Acura's signature family grille and bright, clean headlight treatment highlight the sharply chiseled front fascia while a wide stance communicates a message of strength and stability. For 2003, the MDX is available in three new colors: Midnight Blue Pearl, Sage Brush Pearl and Sandstone Metallic. In addition, it receives redesigned alloy wheels, standard rear mudguards, auto-on/off headlights and rain sensing windshield wipers (w/touring package).
The MDX's interior emphasizes the vehicle's versatile yet refined character with standard-setting levels of luxury and functionality. For 2003 a variety of enhancements have been made to ensure that all materials and accessories reflect the highest level of craftsmanship and refinement. Three uniquely transformable rows of seats allow the MDX to comfortably seat up to seven passengers. Second and third row seats split and fold flat into the floor providing 82 cubic feet of cargo room. Even with all three rows in use, the MDX still offers 14.8 cubic feet of cargo room behind the third row seats.
The comprehensively equipped MDX comes standard with a host of luxury features, including a seven-speaker AM/FM/Cassette stereo with in-dash CD player, a multi-function digital trip computer and a synchronized climate control system. Standard safety features include dual-stage, dual-threshold driver's and front passenger front airbags. The driver's side airbag adjusts deployment force to one of two rates according to input from sensors, which monitor the severity of the impact, seatbelt usage and, new for 2003, the position of the driver's seat. Front passenger's airbag deployment takes into account the severity of the crash and the passenger's weight. The MDX also offers driver's and front passenger's side airbags with exclusive occupant position sensors in the passenger's seat; and the LATCH (Lower Anchors and Tethers for Children) system on the second row of outboard seats to simplify child seat attachment.
While the MDX is already one of the most comprehensively equipped vehicles in its class, an optional Touring Package adds a variety of premium features. These features include a roof rack; exclusive alloy wheels; an upgraded 200-watt, eight speaker Acura/Bose Music System with 6-disc, in-dash CD changer; driver's and front passenger's 8-way power seats, and outside door mirror memory system.
For 2003, the optional Acura Navigation System gets a variety of new features and greatly enhanced capabilities including a newly developed voice recognition system, upgraded graphics and an expanded database with more than seven million points of interest. A rearview camera has been incorporated into the tailgate, which transmits a rearview picture to the navigation screen when the MDX is in reverse gear.
A new Acura DVD Entertainment System can now be ordered as a factory installed option. The DVD player mounts below the standard audio system and plays over the MDX's sound system or through a pair of cordless infrared headphones. The 7-inch LCD screen is mounted to the headliner, just behind the front seats for use by rear seat passengers. The system can be controlled either by using the MDX's audio controls or from the rear seats through the use of a remote control or the screen's control panel.
Like all Acura vehicles, the MDX comes equipped with a comprehensive 4-year/50,000-mile limited warranty that includes Acura's TLC (Total Luxury Care) customer service package.
For more information about Acura vehicles, please visit www.acura.com. For media inquiries, please go to www.acuranews.com.
Thanks.
Specs....
2003 Acura MDX Specifications
POWERTRAIN
MDX
Engine Type
3.5-liter, SOHC VTEC 60-degree V-6
Horsepower, SAE Net
260 hp @ 5,750 rpm
Torque
250 lbs-ft @ 3,500-5,000 rpm
Redline
6,300 rpm
Bore and Stroke
3.5 in x 3.66 in (89mm x 93 mm)
Displacement
212 cu in (3471 cc)
Compression Ratio
10.0:1
Induction System
Multi-Point Fuel Injection
Valvetrain
Variable Valve Timing and Lift Electronic Control (VTEC'), 4 valves per cylinder, belt-driven, single overhead camshaft
Engine Block
Aluminum alloy
Emission Control
Electronic ULEV-2 emission control
Ignition System
Direct ignition system with knock control
Alternator
130 amp. max
Battery
12V, maintenance free
Recommended Fuel
Premium Unleaded
Layout
Transverse mounted, front engine, four wheel drive
Drivetrain
VTM-4(TM) Variable Torque Management(TM) 4-wheel drive
Transmission
Electronically controlled, 5-speed automatic with Grade Logic Control
Ratios (:1)
1st / 2.693
2nd / 1.566
3rd / 1.023
4th / 0.729
5th / 0.531
Reverse / 1.889
Final / 4.375
CHASSIS
MDX
Body Type
Steel unit body
Front Suspension
Independent strut with "L" arm
Rear Suspension
Independent multi-link with trailing arm
Shock Absorbers
Gas-pressurized
Stabilizer Bars
Front
23 mm diameter
Rear
20 mm diameter
Steering Type
Variable power-assisted, rack-and-pinion
Steering Ratio
16.9 : 1
Steering Wheel Turns (lock to lock)
3.22
Turning Circle (curb to curb)
37.2 ft (11.34 m)
Wheels
17 x 6.5 JJ cast-aluminum alloy
Tires
P235/65R17 all-season
Braking System
4-wheel disc brakes with 4-channel Anti-lock Braking System (ABS) and Electronic Brake Distribution (EBD)
Front Discs
Ventilated 11.8 in (300 mm) diameter; 1.1 in (28 mm) rotor thickness
Rear Discs
Solid 12.3 in (313 mm) diameter; 0.4 in (11 mm) rotor thickness
Total Swept Area
Front: 63.5 sq in (409.6 cm2)
Rear: 35.0 sq in (225.9 cm2)
4-channel system with 4 wheel speed sensors and electric/hydraulic control
CAPACITIES
MDX
Crankcase
4.2 US qt (4.0 L)
Cooling System
9.5 US qt (9.0 L)
Fuel tank
19.2 US gallons (72.7 L)
Volumes
Passenger
161.5 cu ft
Cargo with 2nd and 3rd row seats down
81.5 cu ft
Cargo with 3rd row seats down
49.6 cu ft
Cargo behind 3rd row seats
14.8 cu ft
FUEL ECONOMY
MDX
EPA Fuel Mileage - City / Highway
17 / 23 MPG
EXTERIOR DIMENSIONS
MDX
Wheelbase
106.3 in (2,700 mm)
Track, front
66.3 in (1,685 mm)
Track, rear
66.5 in (1,690 mm)
Overall Length
188.5 in (4,789 mm)
Overall Width
77.0 in (1,955 mm)
Overall Height
68.7 in (1,744 mm)
Minimum Ground Clearance
8.0 in (203 mm)
Approach / Departure Angle
Approach - 28
Pics of 2003
MDX
The 2003 MDX receives a variety of substantial powertrain, styling, comfort and convenience updates. The new 260 horsepower engine and all-new transmission provide outstanding power in a state-of-the-art V-6 package. In addition, the MDX receives Vehicle Stability Assist (VSA) to help enhance control during acceleration, cornering and accident avoidance maneuvers.
Enhancements for 2003 include:
Next generation engine increases horsepower from 240 to 260
All-new compact 5-speed automatic transmission
Drive-by-wire throttle
Revised suspension settings
35 percent increase in dynamic torsional body rigidity for a smoother ride
Refined steering system for enhanced feel and reduced kickback
Available Acura DVD Entertainment System with headphones and remote control
Improvements to the optional Acura Navigation System including:
o Voice recognition
o Enhanced graphics.
o Rearview camera
o Expanded US data base coverage
Dual-stage, dual-threshold front airbags
Additional front airbag sensors and new system control logic
New alloy wheel design
Auto-up driver's side window with auto-reverse (similar to CRV)
Rain sensing windshield wipers (Touring Package)
Auto on/off headlights
New exterior colors:
o Midnight Blue Pearl
o Sage Brush Pearl
o Sandstone Metallic
New interior color-Quartz
Rear splash guards
Honda/Acura Transmission Problem from Acuramdx.org forum
Premise:
As you may have heard, Acura/Honda has recently experienced a major problem with it's automatic tranny. The two problematic transmissions are the FIVE-speed used in V-6-equipped Acuras since the 2000 model year and in Honda Odysseys since the 2002 model year; and the FOUR-speed automatic used in V-6 Honda Accords since 2000 and in 2000 and 2001 Odysseys.
Honda has replaced the transmissions in about 16,000, or 1.6%.
Hey all,
As you can read, the Acura MDX is supposedly NOT affected by this faulty transmission problem. However, the MDX is relatively new (only 2 years on the market)...only a few MDX out there have over 50,000 miles (thus, that stat is a bit misleading). In addition, most MDX drivers don't "gun" their SUV down the road, and also they don't off-road that much. Most of the tranny failures are seen in high-stressed vehicles, aka Acura TL Type S. So, the MDX may not have a problem after 10,000 miles...but how about after 50,000 miles??? or 80,000 miles?? Or just when the warranty expires??? The '02 Odyssey is also beginning to have this problem...the '02 Odyssey has a 5-speed auto tranny like MDX (and Pilot) too.
In additiion, if you read the article closer, this defect ALSO affects the older 4-speed automatic tranny in Honda Accords!! That tranny has been around since 1998. Does this mean that the defect is a FUNDAMENTAL problem among ALL Honda automatic transmission??? As VICPAI noted, it seems to be a "wear problem" with the 3 gear clutch pack .....in other words a durability issue".
However, I had my '97 CRV until 99,700 miles without any problems. These miles also included many off-roading trips and towing. Of course, i changed the automatic tranny fluid on schedule.
Thanks.
Honda's Response
Honda To Extend Warranty on Some Vehicles' Transmissions
Earle Eldridge
Honda said Thursday that it will extend the warranty on vehicles with a problem transmission to seven years/100,000 miles.
The company also said it will reimburse those owners who paid to have transmissions replaced.
The moves came after angry owners swamped online forums and appealed to the National Highway Traffic Safety Administration for a safety recall because of a transmission that could slip out of gear, not go into gear, abruptly downshift or refuse to shift.
The extended warranty applies to 2000-01 Honda Odyssey minivans; 2000-01 Honda Accord cars with automatic transmissions; 2000-01 Prelude; and 2000-03 Acura CL and TL cars.
Honda says the extended warranty, which covers the transmission only, affects about 1 million vehicles. It says 1.6% of those vehicles have had to have transmissions replaced.
''We wanted to make sure our customers still believe in Honda, and we didn't want them to have any lingering doubts about our quality,'' says Kurt Antonius, a Honda spokesman.
Honda will send letters in the next few weeks to owners of the vehicles, notifying them of the extended warranty and offering reimbursement.
For vehicles still under the three-year/36,000-mile warranty given when the vehicle was purchased, Honda had been replacing the transmissions. But owners with problems after the warranty expired were required to pay for the new transmission.
The problem varies with each model, but Antonius says the culprit is a bearing inside the transmission that could break apart or premature wear of a third-gear clutch part that could scatter metal bits inside the transmission case.
Some owners said their transmission had to be replaced with as little as 1,200 miles on the vehicle.
David Champion, director of Consumer Reports magazine's Auto Test Division, says owners should reasonably expect a transmission to last for 120,000 miles.
These two stories from Acuramdx.org clearly show the weakness in the Acura's transmission:
#1:
Sand anecdote
My MDX does quite well in the deep, soft sand on our barrier beaches. I was out on a blistering 95+ degree day this past summer. Who knows how hot the sand was? The transmission overheated but I was on a one-way, rutted path with no place to pull over so I had to continue a ways to a wide spot with the A/T Overheat light on. That hurt, mentally. But the X cooled itself off after a few minutes of idling. Just do as the manual states: stop someplace safe, put it in Park, and wait until the light goes out. It is then safe to continue. The tranny smelled a bit, but I've been watching and sniffing the tranny fluid and it's been fine since that episode, with the fluid being as pink as new.
#2:
1st real off-road - tranny overheats!
I took my MDX on it's first "real" off-road adventure this weekend and climbed up the Sierra Buttes just north of Lake Tahoe. Most of the climb was on a mild dirt-road, but the last two miles were very steep and technical with a lot of big rocks and switchbacks. The MDX did amazingly well, and the 4-wheel drive worked flawlessly. One tire would often begin to spin but then the others would kick-in and take over.
At about the 1.8 miles I noticed that the ATM TEMP light had come on and I quickly stopped and shut off the engine. (BTW, the outside temp was about 80 degrees). I let it sit for about 20 minutes and still the light stayed on when I started the engine. (The electric fan stayed on for the entire 20 minutes, and yet the engine temp was fine). Then I dug the manual out and read that you should leave the engine running when this happens, so I started the engine and after about another 25 minutes the light went off and I was back on my way.
The only other problem was on the way down there was a really steep section where the truck started sliding (straight forward)and thanks to the anti-lock brakes there was nothing I could do about it. (Can you tell that I'm usually not a big of antilock brakes ;-). I maintained firm constant pressure on the brakes and the car just kept sliding (and accelerating!) down the hill. Although my wife came very close to cardiac arrest, no damage was done. I don't fault the MDX or it's braking system - just antilock brakes in general. In situations like this I think that a trained human being can modulate the brakes better than a computer chip.
Thats all - mostly a very positive experience!
Car & Driver Review:
http://www.caranddriver.com/xp/Cara...003/january/0301_comparo_bradsher.xml?&page=1
Third Place
Acura MDX
Add 20 horsepower to an already hauntingly appealing package, and the MDX, now at 260 hp, remains a contender, even in the face of big-time hitters from Lexus and Volkswagen. We have favored this Acura in other SUV evaluations, and this newest iteration is no exception.
THE VERDICT
Acura MDX
Highs: Broad-based performance with no noticeable flaws.
Lows: Suddenly a quart low in the luxury department.
The Verdict: One of our favorites gets some serious competition.
Honda's aged commitment to "keep it simple" is expressed in spades with this Acura. While others in this class demanded manual shifting of their automatics to run quickly in the Ohio hills, the MDX was perfectly content to whistle through the tight stuff with its five-speed stuck in drive. Steering was precise, the brakes unfailingly predictable (if long to stop, at 200 feet from 70 mph), and the suspension remained supple and levelheaded at all times. In raw numbers, the MDX is a third- or fourth-place finisher in the categories that count.
Off-road behavior was again a no-brainer, with the Acura chugging through the wilderness with aplomb, although it too lacks a low range, hill-descent control, an adjustable load-leveling suspension, and a center differential. Add to that its modest 3500-pound towing capacity, and you have a light-duty all-wheel-driver best suited for basic seven-passenger highway operation.
Despite the overall approval registered by our test crew with the Acura's performance, reservations were expressed about the rather elemental interior accommodations as compared with the Lexus and the Volkswagen, both of which offered more comfort and amenities with equal or better performance. But at $41,000, the second least expensive of the bunch, and offering dazzling handling and lightness of touch, the Acura MDX remains a major player in the upscale-SUV world.
Third place is hardly a defeat in this elite collection, and one can only puzzle as to how long it will take Honda to respond to the new challenges being posed by Lexus, VW, and Porsche in a contest for top-dog sport-utility vehicle.
Link:
NCTD.com Review of 2003 MDX
Summary
Acura MDX combines most of the virtues of the SUV genre and diminishes or eliminates most of its vices. Anyone seeking comfort, performance, spaciousness, flexibility, proven safety features, environmental awareness and driving pleasure in a value-loaded package must have a look at the MDX.
Edmunds Follow-up Review of '03 MDX
Follow-Up Test: 2003 Acura MDX
An SUV for All Seasons
They called it a snow track — but it was really more like a skating rink.
High in the mountains near Vail, Colo., Acura workers flooded a golf course driving range with water and let it freeze so journalists could test the new Vehicle Stability Assist (VSA) system (Acura's terminology for stability control) the company has added to the 2003 MDX. VSA is one of a number of upgrades made to the three-year-old SUV, along with a boost in horsepower, a new transmission, bigger front brakes and a rear-mounted video camera integrated into the navigation system for easier parking lot maneuvers.
The MDX's Variable Torque Management (VTM) system, which works in concert with VSA, provided remarkably sure-footed grip on the treacherous course. Take the dreaded "Turn Seven," for example. The sharp, uphill left turn, became polished to a high gloss by lead-footed auto journalists whose response to every situation is more power. When traction was lost and the skidding started, four-channel VSA began redistributing power to other wheels — and even selectively braking — to gain a purchase on the slippery slope.
Amazingly, the MDX pulled its way up and around the turn. Not every time. But it worked well enough, under bad enough circumstances, demonstrating that this wasn't just another bells-and-whistles improvement. This was the kind of feature that could keep you from sliding into a snow bank. It could even save your life.
One driving instructor brought in by Acura explained it this way: "VSA isn't looking out the windshield and seeing what you see. VSA isn't going to panic like most drivers will. VSA is always ready — and it reacts immediately."
Picture this: You're driving along a winding road in some Northern state, daydreaming about what happened at work that day, when you hit an icy patch on a tight curve. You turn the steering wheel but nothing happens. You have a millisecond to react, but your thoughts are back in the office. When you finally wake up to what is happening, you are in full panic mode. You either jump on the brakes or hammer the gas — both bad reactions.
Now picture this: You're driving a 2003 MDX when the above scenario unfolds. The system reacts by cutting power to the slipping tires and braking the two inside wheels to create drag and point the vehicle in your intended direction. You pull out of the skid and continue home thinking about office politics, unaware of the fate you have just escaped.
Before you conclude that danger on icy roads is now obsolete, Acura reminds you that its system is called Vehicle Stability Assist. In other words, it does not promise to overcome danger on the road. But it might well make the difference between restoring control of the vehicle to the driver, rather than surrendering to the elements.
VSA is a welcome addition to the already popular and very capable winner of our 2002 Luxury Crossover Comparison Test and our Most Wanted Luxury SUV for 2002. Introduced in 2001, the MDX became a hit not just because of the Honda/Acura name, but because of its lavish creature comforts, seven-passenger seating, navigation system, responsive engine and carlike handling. And, at a base price of $36,200 (including destination), the MDX gives buyers a lot for their money. (Check TMV pricing to see what other buyers in your region are paying for an MDX.)
Besides VSA, three other changes for the new model stand out: a boost from 240 to 260 horsepower, a smoother five-speed automatic transmission and suspension improvements designed to improve handling characteristics.
By modifying the exhaust system, revising the integrated cylinder heads and installing shorter intake manifold ports, the all-aluminum VTEC V6 goes from 240 to 260 horsepower. Torque is increased from 242 to 250 pound-feet while still meeting ULEV-2 emissions requirements. At 17 mpg city/23 mpg highway, the MDX is more fuel-efficient than many of its thirstier competitors in the SUV class.
An increase in horsepower begs for transmission changes, and Acura designers have responded with an all-new, more compact five-speed automatic. The gearbox is shorter than the earlier generation, and handles the increased torque while providing smoother, quieter shifts.
The four-wheel independent suspension was modified to provide a smooth, compliant ride while preserving what Acura very specifically describes as "sport sedanlike handling." Rear spring rates were increased, while the damping characteristics in the front and rear were improved. The torsional rigidity of the vehicle was increased by 35 percent by reinforcing key structural elements of the body and subframe.
And if that wasn't enough, a number of smaller mechanical changes were introduced, including drive-by-wire technology to more efficiently manage throttle changes, dual piston calipers for the front braking system and standard 17-inch alloy wheels shod with P235/65R17 all-season tires. The navigation system got a voice-activation feature, enhanced graphics and a video camera that automatically displays (on the navigation screen) what is behind the vehicle when it is put in reverse. With tall SUVs, and a high tailgate, the rearview camera is a much needed safety feature as it displays an area broader than just the width of the car.
Changes to the exterior styling of the MDX were minimal. Besides the redesigned alloy wheels, rear mudguards are now standard with the Touring Package, and three new colors have been added: Midnight Blue Pearl, Sage Brush Pearl and Sandstone Metallic. The new blue, in particular, nicely offsets the lines that are sometimes unkindly labeled "bland" — one of the few criticisms of this otherwise winning vehicle.
Following our hair-raising trips around the ice track, we had a chance to drive the '03 MDX on the winding mountain roads near Vail. The extra 20 horses were not overwhelming but, given that we were at altitudes between 7,000 and 9,000 feet, and the engine was sucking rarified air, the power felt more than adequate. The shifting of the new transmission was seamless; downshifts were immediate and made good use of the quiet and refined V6. The highly touted sedanlike handling was not overrated; while the suspension was just a touch soft, it seemed perfectly tuned for the average driving public that wants to believe all roads are smooth.
During our drive, the heated leather seats provided comfort and support, and we appreciated the handsome interior replete with Bose audio, a power moonroof and a full roster of convenience features. The test cars were equipped with the Touring Package that includes navigation and entertainment systems and have a sticker price of $42,500.
While the MDX will not be tackling the Rubicon Trail anytime soon, it will probably be a big hit with those who purchase it with an eye to family vacations and foul-weather commuting. It offers a pleasing combination of luxury and performance, and the standard third-row seat means it can equal the hauling capability of minivans. Throw in the all-wheel drive and VSA, and you have a vehicle that can safely tackle the most precarious roads in the worst weather.
Link:
Vancouver Sun Review of MDX
Worth the premium price
Angela Forgeron National Post
You've set your mind on a sport-utility vehicle ... But your heart still yearns for the sensations you get from a performance luxury car.
It sounds like advertising mumbo-jumbo written to tug at the heartstrings of a potential new-vehicle buyer, but after a week in Acura's MDX, the pamphlet literature couldn't be more dead on.
The seven-passenger, mid-sized, luxury sport-utility vehicle drives like a car but offers the cargo and passenger space of an SUV. And for the city, the refined looks of the crossover let it blend into an upscale, urban neighbourhood or tackle the trendiest turfs in town.
Three years in, Acura's entry into the sport-ute market has undergone some prominent changes that will likely help the MDX stay at the top of the sales chart. For 2003, the MDX has upped its horsepower by 20 to 260; it has a new, smooth-shifting five-speed automatic transmission and a new Vehicle Stability Assist (VSA) system.
Add luxury comforts such as a Bose six-disc CD changer with eight speakers calibrated for the MDX interior, rear-seat controls for the automatic climate control system, a near-all-leather interior with heated front seats controlled by a two-position high/low switch and rain-sensing windshield wipers and the MDX sits pretty at the front of the class ahead of the BMX X5, Mercedes M-Class and Lexus RX 300.
The Canadian-built MDX features a third row, with seating for up to seven. Unlike minivans where you have to ditch the third row altogether if planning a weekend getaway with another couple and lots of stuff, the back two seats in the MDX fold flush with the floor. The last row also splits 50/50, which would be the ideal solution to accommodate six riders and a cooler to stash picnic goods for a day at the beach (if summer decides to descend on the city this year). The second-row seats split 60/40 and fold forward.
The third row did not get much use during test week, but a hop back there -- it is awkward getting to the back and sitting comfortably there due to limited legroom -- is best left for the kids.
During its week roaming around the city, the MDX was put through the rigours of urban life with the help of a family of four. Relatives were visiting from out of town -- a devoted soccer mom and dad, who are regular chauffeurs for their children, 11 and 14.
Jason, the youngest of the two children, was super-excited about getting a ride in the "Aztek." To some young boys, it seems, all SUVs look the same.
The MDX features elegant and graceful lines, with a hint of ruggedness. Its attractive looks haven't changed much for 2003, and they need not.
With dad in the second-row middle seat, it was the perfect time to test the MDX's handling -- and the new VSA system. As tight as the Acura could take an off-ramp, the independent suspension system held the turn as crisply as if taken in a sports sedan. The VSA system kicked in during hard cornering by slowing down the throttle and/or applying brake force to the front wheels as needed. With mom up front -- who first commented on the precise handling -- dad chose to roll to the side anyway to squish each child against the door to hear them squeal.
On the highway to the
2003 Acura MDX: Luxury SUV enters no-spin zone
I'M MANEUVERING A 2003 Acura MDX over an icy driving course in Colorado's Eagle Valley. Driving instructor Lea Crouteau, who's also a professional race driver, is patiently providing adult supervision.
"Look where you want to go," she reminds me for about the 100th time, "not where you don't want to go."
Too late. I've lost my line into treacherous Turn Seven and despite Crouteau's warning, my eyes glance out at a glaring patch of ice. The MDX is losing traction and starting a skid that could take us right into a huge snowbank.
But not this time. Among the MDX's new features this year is a vehicle stability system. When the rear wheel lost its grip, an onboard computer gave orders to brake the slipping wheel and modulate the throttle. With a reassuring little shudder, the other three tires took hold, and I was safely back on track and looking down the straight-away toward Turn 8.
The MDX has been much in demand since it was introduced in late 2000 as a 2001 model and named North America Truck of the year by a jury of auto writers. Built on the chassis of the Honda Odyssey minivan, the MDX combines many of the best qualities of SUV and minivan in a versatile, though costly, package.
Still, Acura cannot afford to be complacent. Competition in the luxury SUV segment is intense, despite the best efforts of some vocal SUV-o-phobes. In addition to a parade of worldwide competitors (see specifications box), this year will see the launch of the new Cadillac SRX, Infiniti FX45, Volkswagen Touarog and Chrysler Pacific.
To do battle, MDX picks up 20 more horsepower for 2003, giving the 3.5-liter V-6 engine 260 muscular horses. It also gets a new five-speed automatic transmission that provides smoother, more precise shifts. In addition, it has an ultra-low emission rating (ULEV).
2003 Acura MDX
Base price: $35,700
Annual cost to insure: $2,228
Engine: 3.5-liter, SOHC V-6
Horsepower: 260 @ 5,750
Torque: 250 pound-feet @ 3,500-5,000 rpm
Transmission: 5-speed automatic
Brakes: 4-wheel discs with ABS
Drive: all-wheel
Seating capacity: 7
Turning circle: 37.2 feet
Curb weight: 4,420 pounds
Towing capacity: 4,500 pounds
Fuel capacity: 19.2 gallons (premium)
EPA mileage: 23 highway, 17 city
0-60 mph: 7.8 seconds (Car and Driver)
Dealers: Acura of Concord, Concord; Golden Gate Acura, Colma; Hopkins Acura, Redwood City; Mike Harvey Acura, Burlingame; Oakland Acura, Oakland; Pleasanton Acura, Pleasanton; Stevens Creek Acura, Santa Clara
Competition: BMW X5, Infiniti Qx4, Lexus RX300, Lincoln Aviator, Mercedes-Benz M-Class, Volvo XC90
The optional navigation system has been upgraded with voice commands, larger screen graphics and a rear camera that puts the area behind the vehicle on screen when the car is in reverse. This could save a thoughtlessly placed bicycle - or a toddler's life. It's a terrific feature.
After several laps of tiptoeing around the icy track, I was eager to take the MDX out on some nice dry pavement for the kind of driving we do in the Bay Area.
Here, even at 8,500 feet, an altitude at which car engines are said to lose about 10 percent of their power, the MDX pulled up mountain roads with ease. Steering has also been refined this year, giving just enough assist to provide a nice feel of the road.
The MDX has a spacious cockpit with the clear gauges and easy-to-use controls that are characteristic of Acura. It has seating for seven, or the third row bench can be folded easily into a well in the floor for a big flat cargo space and seating for five:
Further virtues:
Second-row seats have the ability to recline, unlike in some SUVs in which rear passengers are forced to sit bolt-upright. Seats also slide forward or back to optimize either leg room or cargo space.
Second- and third-row seats fold or split to offer up to 82 cubic feet of cargo area. The third-row bench tumbles into a well to make a flat cargo floor.
In the DVD-equipped models, rear passengers get a cordless remote for audio and video functions.
Storage is ample and thoughtful. Up front, there's a two-tiered compartment with a top tray for cell phone or notepad, and a bottom bin large enough to hold a full box of Kleenex or 13 CDs.
Complaints are few:
The DVD is great for pacifying those second-row passengers, but when it's in use, the 7-inch screen blocks a portion of the driver's view out the back.
The fake wood trim looks like, well, fake wood.
The MDX's base price is $35,700, and don't expect discounts on this popular vehicle. All models come with front and rear climate control, remote-control locks, power sunroof, CD stereo, tilt steering wheel with audio controls, leather upholstery for the first two rows of seats, "wood" trim, cruise control, heated front seats, and power windows/mirrors/locks. About 75 percent of MDX buyers are expected to order the touring package, which adds $2,600 to the bottom line. This brings power passenger's seat, memory settings for the driver's seat, eight-speaker Bose sound system with in-dash CD changer, rain-sensing windshield wipers, roof rack and alloy wheels. (Snow, by the way, didn't trigger the wipers.)
Buyers who opt for the navigation system ($2,200) and the DVD ($1,500) can end up on the high side of $40,000.
That still won't get you a professional driver to ride shotgun when you take the MDX up to Tahoe during a blizzard. But trust me, the stability system is the next-best thing.
THIS 'N' THAT: The MDX is built in Alliston, Ontario, near Toronto . . . Acura expects to sell 50,000 MDXs in 2003 . . . 3,811 were sold in January, up 11 percent over 2002 . . . the average MDX buyer is a college graduate age 35 to 45, who works as a professional or an executive, is married and has two children and a dog.
Link:
Forbes Review of MDX
HIGHS:
Superb finish quality; excellent handling; very spacious.
LOWS:
Not cheap--but what is in this category?
Excerpt:
Should You Buy This Car?
A few years ago we drove the MDX for the first time and were properly wowed. We had it on loan during a snowstorm and only wished it had stability control to keep it going straight on very slick roads. Now the MDX gets stability control, an even more potent engine, an improved all-wheel drive system and sportier handling. We suspect the forthcoming Infiniti FX45 will be a better-handling machine, but it won't have seating for seven; the BMW is also a better handler but, again, it's smaller.
The Volvo XC90 is slightly less sporty than the MDX, but competes very closely on all the amenities that matter to families, such as safety, utility and an alterable interior that, like the Acura's, lets you carry people and things in varying quantity, all depending on what you need to accomplish.
Which is better? That's almost an impossible call. We like the MDX engine better, since response is a bit cleaner than that of even the top-line T6 Volvo engine (despite the latter's superior torque and horsepower). The MDX may not actually be any quicker or handle better, it just feels more willingly sporty.
Then again, the Volvo XC90 features anti-rollover technology found in no other vehicle sold and has more safety technology than you'll find anywhere, double period.
And with a middle (second-row) seat that slides forward toward the front seats, the XC90 out-clevers the MDX if you're a nervous parent who wants ready access to a kid in a child seat.
Want us to waffle some more? OK, the XC90 is so hot that getting a hold of one for anything close to invoice isn't going to happen until later this year, when supply finally matches demand, while demand for the MDX is merely strong, not manic. Need one now? Get the Acura. It's as good a crossover as there may ever be.
Link:
Chicargo Tribune (Cars.com) Vehicle Profile of 2003 MDX
AT A GLANCE
Base List Price*
$35,700
Base Invoice Price*
$32,162
Destination Charge*
$500
Good
- Ride & handling
improved in 2003
- Electronic stability
system
- Exemplary crash-test
ratings
- V-8 power, V-6 mileage
- Effective all-wheel drive
- ULEV emissions class
- Seven seats standard
Bad
- Tailgate window doesn’t
open
- No curtain airbags
- 4-by-8-foot cargo
doesn’t rest flat on floor
- Few “a la carte”
options
- Limited supply
Bottom Line
A versatile vehicle that combines a lot of what’s good about SUVs, minivans and cars — and leaves the shortcomings behind
