Fog lights as DRL?
benormous
I haven't looked into this b/c my truck is in the shop getting a new timing belt, so this is just an idea at this point.
I have a 2001 SR5 without fog lights. But if I'm remembering correctly, the wiring harness is there. I basically want to add fog lights and use them as DRL's. I am wondering if you guys think it would be possible to:
A) Add OEM fog lights to an SR5
and
B) Disable the DRL's and use the fog lights as DRL's.
I don't think I would need a fog light switch b/c they would be on all the time, so I wouldn't need a new steering wheel stock.
What do you guys think?
i took apart my dome light and wired in some interior light like that! it works great when i open the door, no reason why you couldnt run the wire to the fog lights
Just to follow up on my own thread. I got the fog light kit above and it works great. It came with all the hardware and pretty good instructions. The kit comes with a switch and instructions to tap into some wiring under the steering wheel. Just for reference, to add a steering wheel light switch stalk with a fog light switch the following parts are needed (according to trdparts4u)
82998-12420 x2 - $3.98/each
84724-35020 - $66.28
benormous--- how are you liking the lights?..are they bright are they worth the price?..i got a 02 sport wit the switch already on the sterring wheel and the holes in the front....so if i ordered them just hook them up and i would be fine? i was wondering about the harness that has been hanging there since i got the car about two years ago.. anyone think that i would need to get a new harness cause its been sitting there and might not work from all the rain, snow, salt ect...
I like them a lot. They are pretty bright and fairly white. They make my headlights look yellowish, I might have to get some different headlight bulbs. I paid $120 shipped for my kit. I bid on the ebay item below, but didn't win. I got a 2nd chance offer from the seller and I offered him $120 shipped. The seller agreed and shipped them out the same day.
http://cgi.ebay.com/ebaymotors/Toyo...318QQhashZitem270257031334QQitemZ270257031334
As far as the wiring, you should be fine. One of my harness plugs was clean and the other hand some dirt in it, I tapped some of it out and sprayed both with WD-40. No problems with wiring so far, but down the line I will probably replace the steering wheel stalk. The kit also comes with the relay, just plug it under the hood. Your install should be super simple if you already have a switch.
