How to automatically roll down all of your windows remotely
This was a fun project to work on that turned out pretty cool.
I wanted to be able to roll down all of the windows on my 1998 Toyota 4runner by pressing a button on my keyless entry remote. My 4runner has a moonroof, a rear window that rolls down, and the normal 4 passenger windows, so there were 6 windows all together.
Here is the schematic for the circuit that does the job:
Schematic
My keyless entry system is made by Autopage. It has several auxiliary channels that create a ground signal capable of drawing 200 mA when a button on your keyless entry remote is pressed. The signal can be grounded for as long as you want by programming the keyless entry system so I didn't need any timing circuitry for this project.
Here is a breakdown of the circuit:
I needed 8 relays total.
- 1 for the moonroof.
- 1 for the rear window.
- 4 for the passenger windows.
- 1 to create a high-current activation signal from the original 200 mA signal.
- 1 to trick the car into thinking that the keys were in the ignition.
As you can see from the circuit the 4 passenger windows work differently than the rear window and moonroof. For the rear window and moonroof you can simply ground the correct wire and voila! your window rolls down. If you try that with any of the passenger windows of a 4runner things start to melt...
I chose not to make the circuit capable of rolling the windows back up because my 4runner doesn't have any sensors that would stop the window motors if anything got in the way of one of the windows. It wouldn't be good if I crushed my dog's tail by pressing the wrong button.
I'll post a video of the windows in action soon. I hope this helps someone because the12volt.com and toyota-4runner.org/ were extremely helpful during the research portion of this project.
Oh and the best part (besides my car not blowing up) was that the entire project only cost $35!
Schematic
