AUX input trouble-06 non JBL
jimsi
When I connect my XM RoadyXT using a mini jack to the mini jack port in the center console the radio has a high pitched tone, even when the T4R is not running. Is it normal that I have add a filter to all inputs to the aux port? I had to do this to my DVD player bc of the same issue. Or is something wrong with radio and should I bring it in? If it's something with the radio, how do I test that it is so that the dealer doesn't blame my dvd player or XM radio?
Jim
Jim
Is this the first time you have used the aux port or was it working ok and now there is a problem?
Update: Going in next Wed for the TSB
Called the dealership and they looked up the TSB and booked me in for next Wed for the fix.
Jim
Whoa holy necro post, so I have this issue as well in my 07. I believe it is 3 parts to fix this issue. New aux port, filter, and wiring harness. All parts are required so that the filter is now inline with the OEM wiring, if that makes sense. They basically changed the wiring on the aux port side to include the filter and now new harness so it all plugs back to the car without a fuss. I think the hardest part is swapping out the aux port. The aux port is stupid priced but can be found on eBay.
Thanks I just got a quote and they are wanting over $170 just for the parts. Found this adapter after some reading and thinking I'm going to give this a try first. Maybe from here I may then go bluetooth adapter
https://www.amazon.com/PAC-SNI-1-3-...01&sr=8-1&keywords=PAC+SNI-1/3.5+Noise+Filter
