Wheel Measurement Question
CJ3Flyr
Super Moderator
EDIT: This should be correct now...:
Ok wheel gurus, very basic question regarding terminology. For some reason I have never been able to keep this straight.
If you have a 7
Hi Chris, the spidertrax spacers measure 1.25" or 31.75mm therefore if the 4th gen wheel is 30mm offset then the statement "4th gen T4R wheels w/Spidertrax = approx. 11.0 offset" cannot be true can it? Did you mean to write 1.0mm offset or does it have to do with 1/2 the width/centerline?
Uhhh, I screwed up. I was thinking 1.5 not 1.25. And maybe I don't understand the Spidertrax. Are the 1.25's 1.25" total or each for a total of 2.5"?
EDIT: I think I got it now... They are 1.25" total, .625" each.
J.A. said:
Each spidertrax measure 1.25" in width, 2.50" total trac width added.
:lmao: Hmmmmm. I quickly skimmed this goof ball website and found this quote, "The additional tread/trac width (62.0" factory width, 63.25" trac width with spacers) would be a side benefit as well, offsetting the lift's additional vertical height and providing more stable handling." I should have read farther.
:bash: 63.25" should read 64.50"?
I'll get it:biggrin2: Thank-you for walking me through this. I think I've got it. This is a great resource: https://www.rsracing.com/tech-wheel.html
:cheers:
[/url]
:cheers:
Sounds familiar...will have to get said goof to change it:p Thx.
So is this now true?
4th gen T4R wheels w/Spidertrax 1.25" = approx. -1.75mm effective offset
