Well, I replaced the stock fog bulbs on my new 08 Sport with Hoen Xenonmatch; they match the specs of the stockers perfect, just whiter. The low beams and high beams work and look great, both the fogs exploded after about 5 minutes. My question, how do I get the broken glass and residue out of the housing now. I tried to suck it out with a fairly powerful hand vac with no luck. Is there an easy way to take the housing out so I can clean it out?
Hoen is sending replacement bulbs, they said there must have been moisture in the housing or contaminates on the glass bulb. I doubt the moisture but I will have to inspect the new bulbs prior to install this time as I did not touch the last ones or look them over before I put them in.
Any thoughts?
Any thoughts?
