How to get better throttle response FOR FREE!
So i just figured this a couple hours ago, i was driving my company 2002 tacoma today and i noticed that the throttle response in my 4runner sucked compared to my company tacoma. So i stared at my throttle body for hours and reallized that you can adjust your throttle cable to make it tighter. after 9 years (on mine) my t-cable has stretched out a little. all you need is 2, 14mm wrenches and adjust your throttle body a little. i just thought id share that bit of info with you all.
Hmm...Interesting. Any negatives to doing this?
If I'm on the interstate and press the petal all the way down sometimes it will be 2-3 seconds before it shifts into a lower gear and starts to really acclerate. I wonder if this would help solve the problem.
You can also bring the transmission kickdown (1996-2000 only) and cruise control cables back to spec by tightening the corresponding cables. Both cables are located on the throttle body as well.
I tightened all my cables so that there is no tension but no slack when everything is at rest
Mathew, for us less-than-familar folks, take a photo and post it (as previously suggested) Thanks in advance
Here you guys go.
just tighten the slack out of these three cables
nuts to tighten are circled hope this helps
IMG000812.jpg~original
DewRunner said:
Here you guys go.
To clarify this picture a bit more: The red circle to the left is the cruise control cable. The red circle to the upper right is the transmission kickdown cable. The red circle to the lower right is the accelerator cable. Tighten just enough to remove the slack, but not too tight. Also, cleaning the area (like the spring) from dirt helps too. I spray silicone on the spring and in the cable housings to help with smooth movement and to repel dirt from sticking.
very interesting, i wonder if this answers my question as to why 01 and 02's are so much quicker to the pedal
01 and 02 are drive by wire IIRC so they would be totally different situation.
Ok im sorry for not posting pics or more instructions. Thank you drew for the pic. heres some instructions for you all:
1. Throttle Cable
2. Trasmission kickdown cable
3. Cruise controll cable
Using 2, 14mm wrenches loosen the nut on the left of the 2 nuts (1,2) to the right of the 2 nuts (3) in the direction of the arrows. Then pull the cable tight and move the other nut over to hold the cable in place. It's better to do this with 2 people, have 1 person sit in the car and push on the gas pedal while the other person adjusts the cable. Doing this will allow the person adjusting the cable to see how much slack is still in the line. Adjusting the cable to tight will cause your throttle to be open a little bit, you will know if its too tight if you turn your car on and it idles at i higher rpm than normal. Adjusting the cable to loose will result in having to push the pedal all the way to the floor to get throttle response. Make sure to tighen all your cable nuts and ta da, throttle response.
Clemsonfan15 said:
What is drive by wire?
Dew: What is that filter like thing?
Drive by wire is an electronically controlled throttle (no direct cable connection between pedal and throttle). The 2001-2002 do not have an adjustable kickdown cable (electronically controlled). I think they switched to a drive by wire system to have more electronic features like VSC.
Checked mine out this morning and all the cables are LOOSE! two of the cables are so loose that they are almost out of the little gutters they are supposed to sit in. I brought my wrenches with me today, and can't wait to adjust these at lunch time!
This could be good...
I still can move my throttle cable by pressing my gas pedal, but you're right, the kickdown is now fully electronic since there is only one cable that goes into the TB
I checked mine and there is definitely some slack in the lines. I'm going to have to tighten those up, probably when it gets warmer though.
Lol. Your used to it though. :p This is abnormal for us. We don't even have any snow to show for these cold temperatures. I was really wanting some snow.
i dont want any more snow haha.
well for the questions about my filter....
i really dont know haha. this guy i worked with who had this sick camero told me to put it on there, because see how its all oily like, it would be shooting that oil back threw my intake, and so i cleaned the intake with some carb cleaner and put that filter on there and then had to plug the pipe that connected there before, because its a vacuum line of some sort. so far no ill side effects just a little random oil leakage from the filter.
anyone think im crazy and should take it off?
