Welcome to new Lexus GX470 sub-forum
GatorGreg
Self-Appointed SUV Expert
Staff member
Hey all, I decided to add a little sub-forum for the GX470 since it's basically just a Lexusfied version of the 4Runner. Personally, I'd rather have a Limited - I think the GX470 looks a little goofy - especially from behind. However it does have very good off-road capabilities and it has awesome luxury. Enjoy :)
It will be interesting to see if we get some new members with this forum. The biggest difference I see is that it is a little taller and the rear door is well non 4Runnerish.
I hope the GX 470 people come in a give us thier knowledge. :cool:
FirstToyz said:
Besides the obvious body/interior differences, what are the mechanical and off-roading differences?
Let's not talk about the engine/tranny/t-case since those are obvious.
ground clearance? approach/departure/breakover? Otherwise mechanical twins?
Ok, here goes:
1. Engine, brakes, transmission, transfer case = same as V8 4runner Sport Ed. Why? Well, Sport ed has the bigger front brakes which is found on GX.
2. Ground clearance = same because they share the same wheel/tire, axle housing, and front suspension.
3. Breakover and departure angle favor GX because it can lift it's ass. Can the Limited 4runner do that?? (i am not sure.) I think that the 4runner can only self-level, but i could be wrong.
4. GX with Kinetic suspension (KDSS) has significantly more wheel travel than 4runner and Gx without this option. The KDSS is quite impressive. You can read more about it here:
http://www.toyota-4runner.org/showthread.php?s=&postid=34964#post34964
In my opinion, KDSS is a more significant system than XREAS in terms of handling and off-road ability. XREAS is mainly for on-road handling. KDSS uses larger anti-roll bars, so on-road handling should be good. In off-roading, when the wheels are articulating, KDSS disconnects these anti-roll bars, allowing for amazing wheel travel in front and rear. So, it's a double benefit.
5. GX also has electronic adaptive shocks that can change from sporty to comfort setting.
6. More headroom in GX because it is taller, while 4runner is more sporty (thus less headroom).
7. GX has more sound deadening material and thicker front glass...all to make it Lexus quiet.
Well, i think that's it...feel free to correct me.
Well, i think that's it...feel free to correct me. [/B]
If you purchased the V8 4x4 Limited w/ option "NF Rear Air Suspension w/X-Reas Shocks" @ $1,400.00 the 4runner can lift (or lower) its ass just like the GX470.
jlb
jlb
Cool...thanks...learn new things everyday....:)
