FIRST RESULTS OF SIDE IMPACT CRASH TESTS on Small SUVs
Thai
Elite Member
Link:
IIHS First SIDE Crash Test Results (on Small SUVs)
The Subaru Forester is the only one of the 12 small SUVs to earn a good rating in not only the side impact crashworthiness evaluation but also the Institute's frontal offset crash test.
Forester is best performer and Outlander is worst: The side airbag in the Subaru Forester kept the injury measures recorded on the driver dummy relatively low. The dummy in the rear seat also recorded relatively low measures, although its head did hit the pillar behind the back door -- an area required by federal standard to limit head impact forces. There was somewhat less intrusion into the Forester than into several of the other small SUVs the Institute tested.
In contrast, the Mitsubishi Outlander was the worst performer in the side impact test. There was more intrusion into the occupant compartment than in many of the other vehicles tested. The Outlander that was tested didn't have side airbags. The barrier struck the driver dummy's head, and the injury measures recorded on the head as well as on the torso and pelvis were very high.
Ford Escape with and without side airbags: Ford offers side airbags as optional equipment in the front seats of Escapes. The Institute tested Escapes with and without this option.
"There was a huge difference in the results," O'Neill says. "The driver dummy with the airbag to protect its head and torso recorded low injury measures, while high measures were recorded on the driver dummy in the Escape without side airbags. Even though the Escape with side airbags was a good performer in this test, it was only marginal in our frontal offset test."
FEDERAL MOVING DEFORMABLE BARRIER:
IIHS MOVING DEFORMABLE BARRIER: (notice that it's a higher bumper)
