08-06-2003, 02:21 PM
#1
Junior Member
Junior Member
Adding the Auto Dimming Rear View Mirror
Has anyone ever added the Toyota auto dimming rearview mirror to their 4Runner? I noticed that one of the parts sites had the mirror on sale for 49.95 and I was curious how difficult it is.
__________________
2003 4Runner V8 4x4 Sport
08-29-2003, 12:15 AM
#2
Member
Member
diming mirror
i saw the same sale and had the same question.
Just looked at the ltd and the install doesn't seem too bad. you will need to remove that portion of the headliner to plug in power. The kit seems pretty complete.
Do not buy just the mirror itself, as you will be missing many required pieces.
09-04-2003, 03:22 PM
#3
Member
Member
AutoDimming Mirror
I purchased the Autodimming mirror off brandsport.com (this is the mirror only -- NO INTEGRATED COMPASS OR MAPLIGHTS) for $49... It came in a genuine Toyota parts box... easy two wire hookup... had to release the factory mirror off the bracket, slide on the new mirror and tighten the torx screw to hold it firmly in place. Thin two wire hookup runs up from mirror (plasticbracket included to hide wires that lead up to headliner) along the headliner and down the pillar under the dash. I hooked it up to accessory fuse and a ground point under the dash. Works great and looks totally factory. Installation took less than 30 minutes.
Link: http://www.brandsport.com/toy-pt374-0c020.html
11-01-2003, 09:54 PM
#4
Member
Member
i installed one in my 2000 4runner a couple years ago...just go slow and follow the instructions and you wont have a problem...i didnt remove the headliner i just carefully tucked in the wire harness and it worked fine...good luck
__________________
03 4Runner Limited V8 AWD
Sport Hood Scoop
Hood Protector
Yakima Rack System
Westin Safari Light Bar - Color Keyed
Husky Liners and Cargo Mat
DVD Player
Iforce Emblem
Valor Exhaust Tip
OBX Racing Pedals
Chrome Grill Inserts
Tint
Wishlist - BFG A/T KO's
2000 4Runner LIMITED - White
Husky Liners
Husky Cargo mat
Sunroof/Hood Deflector
1997 Harley Davidson FLSTS
11-05-2003, 03:35 PM
#5
Junior Member
Junior Member
Toyota installation manual
Attached is Toyota's installation manual for the electrochromatic rear-view mirror (Gentex).
* Woody
__________________
2003 Toyota 4Runner V8 Sport
11-05-2003, 03:48 PM
#6
Registered User
Registered User
Strong work Woody!
Thanks for scoring that... any doc/manual is helpful.
11-24-2003, 01:22 PM
#7
Junior Member
Junior Member
Thanks to this Thread!
All-
Thanks to this thread, I ordered thjis mirror from Brandsport and put it in this weekend.
Now I just need to figure out the foglight thing.....
Mark
__________________
2003 SR5 4WD Imperial Jade
01-25-2004, 01:16 PM
#8
Member
Member
Brandsport got smart - Raised the price back up!
Brandsport got smart and realized this could be used on newer model vehicles and raised the price back up to $294!!! I'm glad I bought mine when I found it for $49.
__________________
Black 2003 SR5 V6 4WD (Option Pkg C) ClearBra, painted pinstripes Mods: Rear glass limo tinted/ fronts 27%, Sunroof Deflector, Auto Dimming Mirror, VVT-i emblem, Homelink, Valor Tip -- Aftermarket: Weathertech Deflector, AVS Ventvisors & Tailshade tail light blackouts, Silver Star bulbs, 7.2" Widescreen TV/DVD, PNI Wayfinder Compass, K&N Air Filter (Part #33-2281), Husky Cargo Liner, Wood Trim Kit, Third Brake Light Flasher, Amber Whelen Slimlighter (aux. rear hazard warning) Rear foglamp housings modifed for aux. tail/brake/signals/hazard (See Rear Fog Mod Thread here : http://www.toyota-4runner.org/showth...threadid=1137)
03-01-2005, 06:56 PM
#9
Junior Member
Junior Member
Mirrors what to get...
I see that Brandsport now has some aftermarket auto dimming mirrors. I did some research and found that this is the company that manufactures Toyota's mirrors for them.
Should I just get the auto dimming or go all out with all the goodies and get the one with compass and temp? I don't think it's much harder to install is it?
Here are the choices:
Auto Dimming Mirrors
Not sure which one I want to pick up and suggestions?
p.s. just an fyi, if you use the coupon code ttrora when you check out, you can get 10% off your order. ;)
03-02-2005, 02:37 AM
#10
Junior Member
Junior Member
Quote:
Originally posted by toyotadude77
FYI, the hardest part of the install is finding wire A9 to tap into. If you use the pdf manuals located on this site, it clearly shows you the location of A9.
Toyotadude77, where are the manuals "on this site" located? I can't find them. I will soon be installing the mirror I received today from Toyotaparts4u (great service, btw), but I have yet to see a clear picture or diagram showing exactly where the sacred A9 tap wire is (other than somewhere behind the kick panel). Thanks.
__________________
MNTim
2005 4WD V6 Sport (silver)
03-02-2005, 11:23 AM
#11
Senior Member
Senior Member
Here are pics of the installation points from the last time this was discussed.
http://www.toyota-4runner.org/showth...r&pagenumber=2
__________________
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04
Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver
Future Mods: 115V Inverter, Leather, Trip Computer Fix
03-02-2005, 06:52 PM
#12
Member
Member
??????? From $49 to $294 ???????
I would like to get one with Homelink and I called MITO http://www.mitocorp.com/flash/homeli...ingmirrors.htm and it's $399, which I'm not even sure if it will fit my 2000.
03-02-2005, 07:00 PM
#13
Member
Member
toyotaspeed: personally, I would get the auto dimming with the compass because they 4runner, atleast new ones, already have outside temperature and having it in the mirror also would be a bit of overkill. The one thing I always wish i had was a compass though.
on a side note...
does anyone know of a digital guage I could buy (around the size of a turbo timer) that shows things such as battery power, direction... I'm looking for a lil' somethin' somethin'
__________________
Toyota 4Runner 2004 SR5 V6 (Silver)
Exterior:
35% tint on front 2 roll downs, Manik grill guard, Manik tail light guards, Silverstar low beams, Silverstar fog lights, Hella 500 Driving Lights, WARN Shackle Hitch, 265/70/17 BFG AT KO, Cornfed 3/2, 3FT Wilson CB Antenna
Interior:
Clarion DX745MP headunit, 2 12" Visonik subwoofers, 1 1400watt visonik amplifier, Uniden CB, Valentine 1, Blinder M-20 Xtreme Jammers, Husky Floor Liners (front only)
03-03-2005, 01:21 AM
#14
Junior Member
Junior Member
Thanks Toyotadude and Rando for the replies.
I installed the mirror today (autodim + compass), and it went well. Actually, I poked around with a DVM and found switched power and ground on the connector going to the sunroof motor, so I didn't have to route the wires down to the kickpanel and the "A9" point. Yes, I am lazy, and no, no fuses blown yet! But since the mirror draws relatively little current, I don't think it should be a problem. We'll see.....
__________________
MNTim
03-08-2005, 03:46 PM
#15
Junior Member
Junior Member
Thanks for the thoughts, I ordered the gentex auto dimming with compass . I found that they had the install instruction for the mirror and it didn't look very hard so I'm feeling pretty good about it.
Auto Dimming mirror install instructions.
I'll let everyone know how it goes once it's in. Thanks for the assist.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
